Quick Question: What is this for?
I had the C2 up on the race ramps and I found this disconnected 'ground' on the right side of the block. What's it for? It's probably been hanging like that for a while.
Thanks, Wayne https://cimg9.ibsrv.net/gimg/www.cor...8626730865.jpg |
Goes from the motor mount to the frame engine mount. If you have a AIM look under RPO U69
(Post 1599732995)
Ground strap for the radio. Just like all the others through out the car. Not a electrical wizard so not sure why it’s needed for the radio operation.
Originally Posted by Wayne88
(Post 1599733003)
What is its function? What's it there for?
(Post 1599733007)
Originally Posted by new vette 62
(Post 1599733033)
It's one of the grounds for the motor. The piece of the motor mount that mounts to the engine is isolated electrically from the piece that mounts to the frame by the rubber in the mount itself. This completes the circuit from the frame to the engine. There are quite a few of them around the car.
(Post 1599733067)
Now I'm confused [anything electrical confuses me]. What, if not the radio, is this disconnect affecting? Everything in the car seems to be working OK.
(Post 1599733090)
It's a ground for noise suppression on the radio that is on the engine, there is one on the throttle linkage, one on the exhaust, and I don't remember where the rest are. You're fine.
On the frame bracket that the motor mount bolts into there is probably a 1/4" hole where the ground strap attaches. Because of the fiberglass body there are grounds everywhere that could cause any resistance to ground.
How that effects the radio I don't know except to keep the spark plug cadence from playing through the speakers. |
Originally Posted by tbarb
(Post 1599733176)
