2015 ZO6 with ZO7 performance package?
I'm looking at a 2015 ZO6 3LZ which includes "ZO7" in the description however I do not see the front splitter end plates or clear wickerbill on the rear in the pictures. The Build sheet says Model: 1YZO7-2015 Corvette ZO6 coupe.
Does the 1YZO7 part of the Model # mean it's a ZO7? Is there such a thing as a ZO7 that did not come with the splitter end plates or the clear wickerbill? In other words for 2015 model year was it possible to get a basic ZO7 that does not include the optional ZO7 Performance Package? Thanks, |
Car comes delivered with the stage 2 aero package. Not all dealers would prep the car with the stage 3 endplates or wicker bill. Those would have been in the trunk at delivery for the owner to install if they were going to the track
So does the Model # 1YZO7 indicate that it is a ZO7, I do not find the ZO7 Performance Package anywhere on the Build sheet.
Maybe the ZO7 in the model number has nothing to do with the ZO7 Performance Package??? |
Does the 1YZO7 part of the Model # mean it's a ZO7? here are the 2015 specs from the corvette museum, note the four model designations at top of page: 2015 Corvette Specs |
Thank you SilverGhost, I know understand that 1YZO7 indicates that it's a Z06 coupe, not a Z06 convertible.
Pull up the carpet at the rear of the cargo compartment where the rear electrical center is located and look at the RPO Sticker. That sticker will have the RPO code for every item that is installed on the car. If the car is a Z07 you will see both the Z07 code and the FE7 code. FE7 represents the suspension used by the Z07. If it isn't a Z07 you won't see the Z07 code but you will see FE6 for the base Z06 suspension.
This is what the RPO Sticker looks like on my 2015 Z06/Z07: https://cimg3.ibsrv.net/gimg/www.cor...5f6bce4684.jpg Bill |
Originally Posted by SCF Buddy
(Post 1599733848)
Does it have carbon ceramic brakes? If so, it is a Z07.
