Vitesse throttle controller
Anyone have long term experience with this product? Please state how long you have had the controller installed and any issues encountered.
Thank you, Mike |
Plenty of posts here on the Vitesse, if you want adjustable throttle response, this product is for you, otherwise it adds no real performance gains. I haven't read too many negative experiences with it
Originally Posted by 99mike
(Post 1599734823)
Thank you, Mike Only problems I had were initially when mounting the controller. First had it tucked behind the carpet and after I posted a pic on the Forum Vitesse saw it and said it could overheat. Other posts showed where it did get hot so putting behind the carpet is NOT A GOOD IDEA. Vitesse said tie to a wire under the dash. First time I did that a plug pulled out and it went into limp home mode. Was in my driveway so no problem. Devised a way to use a plastic tie to attached only the body to a wire bundle under the dash with no force on the plugs. Worked fine. When I got my MRC software upgrade after a year I have been driving in Sport and don't need it! Felt a bit different so I removed. There are other posts about the knob not fitting properly on the shaft and the contact position needed for the initial set-up being affected. Some were getting the unit replaced. Mine did not have that issue, nor was there a lot of comments about that issue. Hope that helps. |
I had one on my C6 GS automatic for several years and loved it. No problems at all. The new Stingray I have is a manual and I use Sport Mode all the time. Now I don't think I need one and get enough throttle response to meet my driving style. A more aggressive driver might feel different though.
Agree with Jerry on this - it is finicky about installation config and needs to be re-calibrated every so often. It had over-revving issues on my custom A&A tune so I ended up removing it to avoid those issues. I went through both the A and B versions with similar results. On NA cars it seems to have no real issues other than needing a re-cal occasionally. I installed a Sprint Booster several months ago in hopes it would not have the same issues and, so far, it's performed perfectly - no over-revving issues. No calibration is ever required on the SB and it's more compact and finished-looking than the Vitesse.
^^^ I had a Vitesse for a while, but had occasional surging when at very low speed, like in a parking lot. A few (not many) others have noted this. I also switched to Sprint Booster and have had no problems since.
Had it since I got my 16 in Nov 15. No problems at all, and it really helps fix the crappy Chevy throttle response at tip in...
I've also heard a ported throttle body can do the same thing. (fix the crappy tip in) I'd say go for it, it's removable and can't possibly affect warranty concerns. |
I've had mine since March 2018. I like the linear throttle response. I've had no issues other then when I initially installed it, one of the pins pushed out and didn't make contact which threw a code. I pushed the pin back in and all has been good.
(Post 1599734823)
Thank you, Mike |
Had one in my C6 for two plus years... never an issue.
Have had one I bought pre-owned for my C7. Old style with the two buttons. No issues in about 15 months. |
I had one installed on my car for a couple of years. The only issue seemed to be the need to recalibrate it periodically. I think there are other throttle controllers out there now that are more technologically advanced and don't need to be recalibrated.
After two years of having it installed, I started to experience a strange "clunk" when traveling at high speed and it was really, really driving me totally nuts. After months of trying to track down what this clunk was, I disconnected the Vitesse and the clunk totally disappeared and never reappered. I don't know why the TC would have caused it, but removing it was the cure. |
I like the Bluetooth Pedal Commander way better.You can adjust it with your phone.
Thanks to all who answered.
Mike |
I've had a vitesse throttle booster on my C6 and C7. Both gave me reduced engine power mode and unintended acceleration in parking lots. I followed all Vitesse's instructions including powering off the car for ___ number of minutes with no fob within 30 feet, calibrating by putting the car in accessory mode, etc. I switched to pedal commander and will not go back to Vitesse. No issues 1 month in.
I had a Vitesse on my Z51 with A&A Supercharger and a custom tune. It repeatedly threw CELs and put my car into limp mode many times. I did the calibration routine many times, and even called Vitesse to make sure I was doing it correctly. I loved how responsive it made the throttle when it worked, but it was just too problematic. Stopped using it and all issues were gone.
End all your problems and get something that works perfectly with no issues, Sprint Booster
Originally Posted by GARYFINN
(Post 1599736320)
i also use it with a PTB, which really makes it even more fun to drive. |
Originally Posted by KCLARK
(Post 1599741012)
FWIW, just installed a Soler (forum Advertiser) modified Throttle Body after I understood that you can increase throttle versus pedal movement all you want via; 1) the OEM changes with Drive Mode, 2) throttle controllers or 3) tunes - BUT can't change the initial air flow through the throttle body unless you modify the entrance and exit contours!
Been following this for some time in the tech section and have seen Posters commenting about modified throttle body improvements. Read all the Soler excellent technical info. Bought one and just installed. A PDF with the reasons for Why it's better is in preparation. It's title is Why to Versus my normal How To Install since that is so easy a few pics are all that took! Discussing choked flow, why the OEM throttle body operates in a contoured are for the 1st 40% or travel- not so simple! "Need to understand "choked flow," converging, diverging nozzles etc OR just evaluate what folks say about performance! The changes are subtitle relative to the time delay BUT your perception to the hesitation is very sensitive! The pic below is complex but summarizers what I found! https://cimg9.ibsrv.net/gimg/www.cor...7003e16be8.jpg |
Jerry,
I've been thinking about replacing my Vitesse unit with the Soler Throttle Body. Do you think it was worth it? Would you do it again? Thanks, Mark |
