1989 A/C Troubleshooting
I know there are a million topics on this but I couldnt find one that fit my car exactly. Just purchased a 1989 corvette with quite a few issues. Want some opinions or something I missed.
Brake booster is toast, ordered another, in the mail. HVAC doesnt work. Electronic climate control unit. Compressor comes on and AC is cold, but blower will not work. Checked and had voltage at the motor connector when disconnected, but when plugged in and probed, no power, fan wont turn. Jumped 12v straight from the battery, and fan spins but pretty slowly. The fan also has power all the time even if the HVAC controls are on or off. There is a power draw when the car is of. I checked all the suggested lights with mercury switches and unplugged them all, still a 1amp draw that I cant find from pulling fuses and unplugging stuff. I am thinking this may be connected with the HVAC system malfunction and possible blower problem. Does the blower motor use a switched power from the resistor, or switched ground. Is it supposed to always have voltage at the motor? Is it supposed to always have voltage at the resistor? |
Since yours is a 1989 model, I presume, it's a L98 model and not a ZR-1.
None the less; HVAC doesnt work. Electronic climate control unit. Compressor comes on and AC is cold, but blower will not work. Checked and had voltage at the motor connector when disconnected, but when plugged in and probed, no power, fan wont turn. Jumped 12v straight from the battery, and fan spins but pretty slowly. The fan also has power all the time even if the HVAC controls are on or off. Most likely your HVAC Fan Control module is toast. It's mounted on top of evaporator housing. https://www.corvettemods.com/C4-Corv...hoC4wEQAvD_BwE I had a situation where battery kept getting drained inexplicably. With the hood open, i heard a faint whirring sound. It turned out that bad fan module was feeding low voltage to the fan even with the ignition turned off. Your symptoms point to fan module failure. |
Yes I was cruising around the different forums and accidentially posted in the ZR forum. My apologies, if a mod could move it that would be great.
I assume that is my issue, I just wanted to see if the fan was a switch power wire or switched ground wire through the resistor. I believe I probably need both fan and module because even with 12v the fan turns pretty slowly. Just want to cover all bases before dropping 150 on the module. |
Originally Posted by Josh Brown
(Post 1599738134)
I always like to come back and recap. I replaced the blower motor and the control module. Found a good new module for 90 bucks off ebay. and the fan was only 30. Runs great now, nice and cold too.
Cool beans, thanks for closing the post out to help the next guy. BTW there were GM Test mules ZR-1s in 89 so..... Glad to hear you got it resolved
