DRM Bilstein in stock
Thanks man! Just ordered. Hope they are worth it! My original shocks only have 9000 miles in them.
Originally Posted by C6Z06Silverbullet
(Post 1599741440)
Originally Posted by psp6158
(Post 1599742122)
Well worth it!! Mine had 6000 when replaced because of the reviews here, and they were right.
(Post 1599742558)
Does it smooth out ride comfort also?
(Post 1599742558)
They also seem to clear up some of the bump steer.
(Post 1599742558)
Are you sure your not talking about my wife?......lol
Shocks came in today! Opened up the box and to my surprise they gave me a free set of upgraded bushings. :thumbs: Once this heat wave goes away i will install them. I will keep you guys posted once they are on the car.
Man you ain't lying about the heatwave; supposed to be bad thru Sunday. Had a storm come thru last evening and didn't do much to cool things down. Have fun with the install, it's fairly easy and the ziptie method works great. Rule of thumb is to tighten the upper nuts until the bushing swells to the same size as the washer if anyone was curious.
Well I put the shop fan on and went to work! DRM's are installed. Haven't gone for a ride yet, car is still in the air since the new side skirts are coming in on Thursday. Install went well, fronts definitely the hardest. Rears were real easy.
(Post 1599773391)
Well I ended up using the poly bushings instead of the rubber. Haven't driven it yet so I will update once I have. I don't know if it was a mess up or they were just throwing them in as a bonus. Possibly they are just included with the shocks now.:confused2:
Also the stock bushings and the poly bushings have a Male and a female end. This is because the hole that the shock goes in is much bigger then the shock shaft. The bushings that come with the bilsteins do not have this. This would leave me to believe that if you don't reuse the stock GM or the Polys the shaft would rub the shock mounting hole and move around. Just my opinion.
Took the vette out last night to dinner, I do feel a difference. Feels less harsh over bumps. Didn't get a chance to get aggressive in the turns yet. But over all so far I do feel like they smoothed the ride a bit. Very interested to see how it affects hard turns with bumps, I always would skip around with the stock shocks.
Mine skips over bumps also ('06) I think it was common for all the early cars until they revised the shocks. Glad it feels better!
06 here too
Anyone not sure if they should get these should for sure do it. I replaced the stock c6z shocks at 12k miles, I now have around 15k miles and I can say it made a huge difference in control and ride quality. Money very well spent!
EDIT: I also did go with the optional poly bushings and had no trouble with install, they fit well and would use them again. |
Would these replace the Selective Magnetic ride? I have the Z07 option. Something is way wrong with the way the car rides and handles lately.
