Help with Twiddlers going out
I have a DNX572BH kenwood unit, hooked to GM0S-04 interface.
Randomly, sometimes 30 seconds, sometimes 2-3 minutes, the twiddlers in the front will quit, everything else continues to work. turning the radio or car off and on resets it to working status. Other than that issue, everything works great, minus a few missing beeps here and there which I can live with. 1) I've tried replacing the 3.5 speakers, first with polks I had on a shelf then with brand new kickers. 2) after much soul-searching, I decided to tear into the dash and see what was up. Moving the potentiometer on the GMOS-04 box when the twiddlers quit cause them to return. They eventually quit again. I don't know if my issue is with the interface box or the bose amp. Car has 90k miles, previous owner did the install (or had it done, looks professional) I could spend $90 on a PAC RP5 GM11, but if Im spending $100, I may as well spend $150 and get a 5 channel skar amp to wire around it all.... Any ideas on where to go from here? |
I just hooked all this up and my next step will be to build a conventional system with an amp wired directly to the speakers and avoid the whole integration thing. If your good with hooking up an amp, changing the front speakers to component..get rid of the bose woofers and getting a sub..I think you'll be much happier. It will cost more than the price of the amp though...RCA cables, speaker cables, power cables, new speakers for the front. The 3.5's will not be enough. Something for the rear. Sub or new speakers or both.
My guess is it's most likely something with the interface. A short or bad connection. I had something similar happen when I was doing my install. Some speakers were cutting out. I replaced the Pac RP5-GM11 with another one and no issues. Luckily I noticed it during testing before I reinstalled everything.
What's a twiddler? Tweeter?
Originally Posted by jdagsxr
(Post 1599760793)
never heard of a twiddler....but OK
Twiddler is easier than saying "not a tweeter, but that small speaker there."
Originally Posted by TorchRedFred
(Post 1599742965)
Thanks for all the help. I picked up the twiddler term here. I suspect it is an amalgamation of tweeter and mid. Didn’t realize it would be controversial. Some people are bored I guess.
I ended up using a kicker 300.1 amp I had around, buying 12” skar sub, and running wiring front speakers direct from head unit. I left door sub and rears hooked to stock Bose amp through interface. I bought a new GMOS-04 (didn’t feel like re-wiring harness) and it was no help so it’s not inteface. Not head unit as speakers work fine wired direct. Guess it’s bose amp or the wiring (although I verified it looks correct per schematic with gmos-04. I may wire up the rears direct direct as well and keep the Bose amped door subs and center (for chimes). Ive already ran RCAs for F and R channel Just in case I decide later to get a 5 channel amp. Did a front and rear camera as well. |
