Water drip + sizzling sound
When I park my car, I see water dripping near front of the car and it's making sizzling noise. Is that normal?
Condensate from the A/C drips onto exhaust pipes on the passenger side of the car.
NORMAL Ron |
Checkout this very recent thread => https://www.corvetteforum.com/forums...r-driving.html
:iagree: This is totally normal
Normal
Every car that has A/C does it. Perfectly normal.
Yep, but the main difference here is the condenser drain is not often located directly above the exhaust manifold. I think most folks are used to the puddle in the garage after AC has been running, but not the sizzling sound.
Yes its normal, its your AC dripping on to the pipes.
Originally Posted by sykr0n
(Post 1599740912)
OK Now I have to listen to hear it when it comes out of winter sleep.
Yes the c7 runs so hot that if I put my iPhone in the arm rest and connected to car play it will go into limp mode. Amazing how much heat this car generates into the cabin.
