-   C4 Tech/Performance (https://www.corvetteforum.com/forums/c4-tech-performance-48/)
-   -   85 AIR pump and EGR deletion... (https://www.corvetteforum.com/forums/c4-tech-performance/4294979-85-air-pump-and-egr-deletion.html)
PacerX 07-12-2019 09:30 AM
I'd like to delete both of these, not to make the car faster, but to clean up the engine bay.
Some questions...
1. Deleting the EGR will set a code, which is no biggy to fix with software, but does it negatively affect performance in any way?
2. Deleting the AIR pump and tubing sets no codes and doesn't affect performance from what I understand.
3. Is the cleanest way to do this buying a set of headers with no EGR or AIR provisions? If so, which set do you guys recommend?
vader86 07-12-2019 10:34 AM
1. No. You can drive around with Code 32 set all day. I have many times. It does not make a real difference in engine temperatures or performance.
2. No it does not affect performance.
3. Yes. Mine are TPiS.
playsdixie 07-12-2019 12:34 PM
you can also reroute the heater hose from the TB....not really necessary and for minimal cost.....helps clean up the engine bay.....
https://cimg3.ibsrv.net/gimg/www.cor...c83c67dbe7.jpg
PacerX 07-12-2019 05:06 PM
That's sexy!
Yessir... TB bypass at the same time seems the way to go.
383vett 07-12-2019 05:20 PM
Simply deleting the egr without a tune can result in part throttle detonation.
PacerX 07-12-2019 11:18 PM
Headers pretty much universally mean a tune anyway, don't they?
vader86 07-13-2019 10:39 AM
Tune isnt required for headers but would be nice. Tune is required for the cam change.
I never got knock with headers on a stock engine, but it is possible.
PacerX 07-13-2019 06:25 PM
Hmmmm… odd.
The rule of thumb on LS's is changing anything between the MAF and the O2 sensors means a tune to either get the power you wanted from the change or protecting the engine.
Interesting.
The TPiS headers you recommend sure look spiffy, but I don't see an "EGR/AIR delete option. Do they offer one that you know of?
aklim 07-14-2019 12:56 AM
Interesting.
I think for the LS the intake is different and more efficient? L98 I would not do a tune on headers. Waste of money until you get an intake at least if not an intake and cam. I don't think the LS intake runs out of steam past 4500 (IIRC)
You might have to call them. Looks like they discontinued the header
aklim 07-14-2019 01:06 AM
I think I found it: https://www.tpis.com/parts/view/235
PacerX 07-14-2019 08:38 AM
Originally Posted by aklim (Post 1599751460)
That's the ticket right there!
Thanks!
