Will the C8 brake pads have the brake dust problems like the C7?
If so I will be ordering low dust brake pads and have them installed at delivery.
How in the hell do you expect anyone to have an answer to that question at this stage of the game?
The C7 only had 'problems' for the show n shine waxers anyway. I'm perfectly ok with cleaning my wheels more often if it gives me a better feeling, grippier brake pad. |
sure, why not? |
Silly Rabbit, the dust comes from global warming and NOT from the pads,
Anything bad is cause by global warming ! |
Only a problem if you want to stop.
OEM pads are a compromise between feel/bite, noise, temp handling, decent life (get out of warranty). Dust isn’t even on their radar. that said, there are awesome options in the aftermarket for pads with decent bite and low/no dust. |
#becausesportscar
I can tell you that my C8 brake pads cause brake dust just as much as the C7 does.
I gotta say my C7 ZR1 doesn’t have brake dust.
D. |
Originally Posted by Pisswilly
(Post 1599751267)
Originally Posted by brAnd7onX
(Post 1599751567)
(Post 1599751267)
(Post 1599751267)
my Z06 z07 had ceramic rotors and little to no dust. I assume that is the pad used.
(Post 1599751567)
I can tell you that my C6 brake pads cause brake dust just as much as the C7 does.
It will probably have the same problem of having to replace rear tires often - I will be ordering lower horsepower/torque and have them installed at delivery.
See Post 3.
Does the OP wish to performance stopping or ability to stop only for car shows? |
Some of these threads are really getting ridiculous. :crazy:
Originally Posted by TA
(Post 1599752147)
These C8 posts continue to get more and more stupid.
depends if you want it to stop 3 feet shorter, which would put the front end into, oh, about the B-pillar of the car in front....
