Broken glass top, how to repair
Is it possible to glue back a piece (about 3 inches long) onto the glass top???
[Modified by vmaxer, 1:23 PM 11/9/2002] [Modified by vmaxer, 1:26 PM 11/9/2002] |
Re: Broken glass top, how to repair (vmaxer)
I wish someone in the know would answer your question, because I was wondering the same thing.
That said, I have an extra bronze top for my 90 that had the left rear corner of it worked on. To me, it looks like a broken piece was glued back on but I really can't tell. So my answer to the Q would be "probably yes". Is there someone on the forum who repairs tops or has access to the panels, etc.? |
Where is it broken? Mine was on the rear corner and the pieces came off clean. Used super glue to put them back together and then cut a piece of light guage aluminum to go under the cracked area. Covered the area with epoxy and clamped the aluminum piece in place. I figure the glue will hold the pieces and the metal backing should keep it stable and reduce stress on the glue joint. Cracks show, but it beats the cost of a rebuilt top.
Hope you can fix yours! |
Re: Broken glass top, how to repair (LaVidaLoca)
Mine was also cracked/broken at the rear corner. I don't want to mess with it in case I re-break it or do some other damage. It seems to be solid enough as it is, so leave well enough alone.
Actually, I would prefer to get rid of it. I have two other tops, both solid ones that are in excellent shape. So I really have no need for this one. Wish someone would read this and offer me $100.00 for it! |
Re: Broken glass top, how to repair (qwerty111)
I emailed you about your top. :seeya
