Squeak up front
I have a squeak that sounds like its coming from the right front. I only notice it when going slow over rough roads or bumps. Any ideas what it could be from? My Corvette is a 2000 c5.
Thank you |
Moved to C5 Tech.
Probably a sway bar bushing, mine was doing the same thing. I have a complete set of red Energy Suspension bushings for the front and rear for $35 shipped if your interested.
Yes, sway bar bushing. This is a common problem. Easy swap and your noise will go away.
lube the hood stops, as mentioned sway bar bushings or end links ???
What do you recommend I lube them with? The person I purchased the car from had the stabilizer links/bushings replaced and also the front swayer links and sway bar bushings replaced already on 11/02/18. I don't know what else to do!!
Joel |
How difficult are they to change?
Joel |
Originally Posted by Sordz
(Post 1599957643)
Joel |
I am interested in the bushings. Will they fit my 2000c-5? Coupe!
Thank You Joel |
Originally Posted by joelcastro
(Post 1599944060)
Thank you |
I thought the auto ride was controlled by the shocks!
Joel |
