Changing color on my Z06 calipers
It is time for me to change the rotors and pads on my 2009 Jetstream blue Z06. The car has the standard red color calipers that have faded these past 10 years. While I'm changing the rotors and pads I want to freshen up the calipers. I was wonder what others have done there Z06's? Any help would be appreciated.
https://cimg3.ibsrv.net/gimg/www.cor...0bb54d290a.jpg https://cimg9.ibsrv.net/gimg/www.cor...ba0729d46c.jpg https://cimg4.ibsrv.net/gimg/www.cor...e78a96d74a.jpg |
How about blue like with the c6zr1
also matches the rest of your car |
That's a good idea. I wonder what color code that is?
Two things you will need to do is refurbish the caliper pins and get new Corvette lettering. I keep both types of lettering, the white and the silver. The caliper pins I put a wire brush on a dremel and shine them up then clear coat them. However you can shine them up and then install then use some clear nail polish over them so that way the torx bit that you use to tighten them wont take the clear off that you already put on.
https://cimg8.ibsrv.net/gimg/www.cor...c13babab79.jpg https://cimg6.ibsrv.net/gimg/www.cor...1e7cdedfd3.jpg |
Originally Posted by robsvette
(Post 1600579510)
Thank you for the advice. I was thinking of going with TPS motorsports. The clear nail polish is a great idea.
Originally Posted by LeManscoupe05
(Post 1600581444)
https://cimg1.ibsrv.net/gimg/www.cor...2db8c319b.jpeg https://cimg3.ibsrv.net/gimg/www.cor...529073e4f.jpeg |
I just bought some high temp wrap that is for calipers, I am going to try it and see how it works.
G2 is the way to go, You can get any color that you want for your calipers, just get the right paint code number
Originally Posted by mcandrew67
(Post 1600583130)
(Post 1600583727)
I'd like to see how that turns out.
I have the silver calipers and did black pins/hardware/lettering to go with the rest of the black/grey/blue theme of the car. Depends on what you're looking to do but red on blue is not classy in my opinion.
https://cimg3.ibsrv.net/gimg/www.cor...501e17ed61.jpg |
Where did you purchase the brake caliper decals?
Originally Posted by drj2011
(Post 1600588489)
As far as the caliper pins go, do you just unscrew them with a torx? Do the pads need to come out or anything? Mine are kinda rusty....
(Post 1600588489)
Originally Posted by 1FUNC5
(Post 1600588706)
most likely eBay
They are not exact on dimensions but are very close to original. The ones I received are slightly larger than stock. |
Originally Posted by REDSEE5
(Post 1600589589)
My GS is JSB and I just picked up some blue caliper paint. Going to try it out and see how I like it.
(Post 1600584756)
there are some good videos of it on Youtube, I got the VVivid wrap
https://www.youtube.com/watch?v=f9Bkuzu9pK4&t=2s |
After I put the new decals on my GS calipers, I gave the caliper a quick shot with hi temp clear paint.
looks good and easier to clean. |
