70 Corvette Vert Restomod, 5 Speed, $15K [FL]
22 Attachment(s)
For Sale: 1970 Corvette Convertible Restomod w/73 style front clip, 5 Speed Transmission
Asking Price: $15K Exterior Color: Monza Red Interior Color: Black Location: Parrish Florida Below is a list of parts/upgrades to the car. I. Engine 350 cubic inch, 430 HP, 425 LBS Torque, built by: Engine Factory, http://www.enginefactory.com/ 4 Bolt Main, Full Round Seal Block Cast Iron GM 350 Crankshaft ZZ4 PM Connecting Rods Speed Pro Hypereutectic Pistons, 10:1 Compression, Part #H345CP Speed Pro Moly Rings Edelbrock Roller Camshaft, Part #2204, Duration @ 050 234/238, Lift 539/548 Edelbrock Double Roller Timing Set Edelbrock Performer RPM Aluminum Air-Gap Intake Manifold w/ EnduraShine, Part #75014 Edelbrock Performer RPM Aluminum Cylinder Heads With 64cc Combustion Chambers, Part #60899 TriMetal Heavy Duty Engine Bearings Melling High Volume Oil Pump, Part #M55HP Screw In Rocker Studs Stainless Steel 2.02" Intake Valves Stainless Steel 1.60" Exhaust Valves Hard Seats And Guides For Unleaded Fuel Chrome Oil Pan, Timing Cover, Air Cleaner, Thermostat Housing And Valve Covers GM Harmonic Balancer Damper Balanced, Blue Printed, Assembled And Painted HEI Distributor with 53,000 Volt Coil and Tachometer Drive Pro-Form Mini Torque Starter, for 168-tooth Flywheel, Part #67052 March Performance 6 Groove Serpentine Drive Bracket Kit, Part #20406 March Performance Billet Aluminum Sanden 508 A/C Compressor, Hooker Full Length Competition Ceramic Coated Headers, Part #2456-1HKR Hot Rod Air In-dash A/C Kit, Part #75-0068 Entropytec Aluminum Radiator with Dual Spal Fans Tuff Stuff CS-144 Alternator 140 amp Chrome Alternator, Part #TFF-8173NA Go EFI Fuel Injection System II. Transmission Keisler TKO 500, 5 Speed Transmission, http://www.keislerauto.com Keisler Hydraulic Clutch Actuator Kit, Part # CAG-HWC3T Pioneer 168 Tooth Standard Flywheel, Part #67052 RAM Automotive Powergrip Clutch Kit, III. Rear End 3.36 GM Stock Rear Differential Gears (Dif. Code: CAM) IV. Brakes Hydratech Hydroboost Brake Booster SSBC Front and Rear Force 10 Extreme 4 Piston Aluminum Brake Calipers, Part #’s A109AFR and A109ARR Van Steel Slotted and Dimpled Brakes Rotors V. Suspension Vette Brakes & Products Front and Rear Performance Plus Kit, Part #42000 VI. Steering Vette Brakes & Products Rack Attack, Rack and Pinion Kit, Part #12904 Van Steel Offset Trailing Arms, Part # BAOE-44-L/R AGR High Performance Power Steering Pump, Part # 806324 VII. Wheels American Racing Polished Torque Trust II, 17 x 8 with 4” Backspace or -11mm Offset, 5 x 4.75 Bolt Pattern If you want to change it back to the 70 front, I have most of the parts, minus the font clip and short hood. Parts: Left/Right Fender Louvers (Egg Crates Side Grills) Front Bumper Right/Left Front Bumper Guards Right/Left Chrome Grilles Most of the brackets Windshield Wiper Door and Brackets I also have the 4 speed transmission that came out of it. |
Very nice! That's a lot of car for $15K, I couldn't begin to imagine how much it would cost to build one like it.
GLWS. :thumbs: |
Extra Parts
Originally Posted by SMF
(Post 1600781070)
If it still had the 70 front end on it, that car would be in my garage. Very nice. Still thinking about it.....
I forgot to mention that if you want to change it back to the 70 front, I have most of the parts, minus the font clip and short hood. Parts: Left/Right Fender Louvers (Egg Crates Side Grills) Front Bumper Right/Left Front Bumper Guards Right/Left Chrome Grilles Most of the brackets Windshield Wiper Door and Brackets I also have the 4 speed transmission that came out of it. |
70 vert
Sent you a pm
70 vette.
Also pmed you
What's the exact name of that hood?
PMed also
This car is a great value if basically everything checks out...Been a C3 vert owner for almost 20 years now...One of the best values I have seen in a while...
Numbers matching ? No....Who cares though...Let someone enjoy it for what it is A solid looking car. Someone who is looking for a tank sticker or astro ventilation markings on the windows, look elsewhere. Sorry guys some vette buyers take it to the extreme when it comes to purchasing a C3.. Good luck with the sale...I personally like the look and the fact it does not have that factory boat anchor of a motor in it... Congrats to the new owner as well when he gets it.....Be safe... |
This car is a decent value so much for "changing things ruins value".
Underhoos has lots spent, 4 spd vintage ac clean, sold. OP whats up with the bushings out back? |
Amazing deal........unbelievable.
Jebby |
70 for sale
PM sent,,,,,,,,,,teddy
Deposit Placed on Vette
A deposit has been placed on the Vette with a pickup of next weekend. If the deal falls through, I'll let you all know.
:lurk:
My dad bought this last week everyone.
Sold
The 70 Vette has been sold and picked up.
Originally Posted by jimrowe0
(Post 1600855867)
(Post 1600855867)
