M7 tranny fluid
I have a 2014 M7 Z51 with about 30,000 miles and I want to change out the tranny fluid. Is Redline D4 ATF a good choice or should I stick with what GM recommends? Thanks.
Redline D4 is vastly superior to the factory fluid. You'll be quite happy with it.
Thank you Kracka
Originally Posted by Kracka
(Post 1601060300)
(Post 1601060300)
Definitely change to the Redline D4. Much smoother shifts.
Same here. Used it on my c7 stingray and now on my c7zo6. Redline is the way to go.
What makes Redline vastly superior to the factory lubrication?
Bill |
High-quality synthetic vs. conventional grade generic ATF.
snake oil
(Post 1601083428)
Bill |
OEM fluid. Visit the Tremec website for info.
I've swapped for Redline D4 ATF based on recommendations here. However, I'll be in the minority group that based on subjective feel OEM GM is better. On my next change I'll be going back to OEM GM fill.
I too just changed to Redline D4 ATF, haven't had a chance to drive it yet.
I ran the car on my lift, the shifts were way better. Now lets see how it is on the street. |
Originally Posted by itch808
(Post 1601092552)
How much do you need to do a fluid swap in the M7
Originally Posted by Scoobydoobydoo
(Post 1601109739)
Originally Posted by SonnyAK
(Post 1601110504)
I think 7.4 pints is the spec. You'll have a little left over from a gallon jug. Be sure to have the car nice and level then pump it in until it just begins to trickle out from the fill opening.
I did D4 with 1qt MTL mix, it is better than straight D4
