2LT dash damaged!!! What could cause this?
I had my car washed by my mobile car guy and he pointed out to me this on my dash. What do you think could have caused this type of damage. I’m thinking some kind of chemical he used by without being sure I don’t want to blame him.
https://cimg1.ibsrv.net/gimg/www.cor...23dd89c3a.jpeg https://cimg8.ibsrv.net/gimg/www.cor...7f5502cfe.jpeg |
They used either Armor All or 303 Aerospace Protectant on your dashboard. Get yourself a Magic Eraser with a soft microfiber towel. Soak the eraser in pail of warm water and ring it dry. You may have to wipe the dashboard down a few times. Be gentle with the Magic Eraser. Dry the dash down with the clean microfiber towel.
Originally Posted by MMD
(Post 1601615843)
I have used 303 for years on my dash and never had a problem. I don’t think Armor All or 303 would do this kind of damage.
Originally Posted by Jonathanmilr1
(Post 1601615860)
Thanks for the replay, you have had this happen to you and your solution fixed the problem?
Originally Posted by Litfuse
(Post 1601615892)
(Post 1601615892)
could a glass cleaner of some sort cause this as well? its soft and gooey in these areas and the vinyl looks wrinkled. |
(Post 1601615905)
It's not damage. It can be restored.
I believe OP is referring to the areas at the edge where it appears the top skin has been removed exposing the foam beneath.
sorry no help here though |
(Post 1601615917)
I will try this tomorrow and I will see it it works thank you
i would not use a Magic Eraser. It is an abrasive. You would not want to use even a fine sandpaper on your interior.
(Post 1601615900)
I had something very similar happen to me on my 3 LT dash. I applied a product for UV leather protection on my dash and it left a very un-uniform shine all over the dash. It looked awful. It took me about 10 wipe downs with a Magic Eraser over 3 weeks and I finally got the dash to look like new. Magic Eraser is a solid product. Wipe it down gently and then dry. Then re-evaluate to see if you need to wipe it down again. Eventually you'll get rid of the nasty stuff on your dash. Your dash can be restored. You can do this. No need to panic. The 2 LT is even more stout than my 3LT.
Originally Posted by Ratboy
(Post 1601615976)
I'm not so sure you're talking about the same kind of damage. His dash looks like parts of it are melted. Its not just some non- uniform shine. I've never seen anything like that, and cant imagine anything in a detailers kit that could do that.
yes it looks like a chemical ate through the vinyl and it’s all gooey now. All I can think of is some sort of abrasive window cleaner the detailed used. It was 100 degrees out when he washed the car so I mont sure if that plays a factor into anything |
Originally Posted by Elk
(Post 1601615967)
Magic Erasers are made of melamine foam, an abrasive cleaner. When melamine resin cures into foam, its micro structure becomes almost as hard as glass. This acts as a fine sandpaper. The edges sand the surface of what you are rubbing it on, and the holes in the foam pick up the residue.
As a test, try a Magic Eraser on your car's finish and let us know what happens. :) |
(Post 1601616061)
(Post 1601615985)
I suspect a petroleum based cleaner of some sort, but I have no idea what would reasonably be used to clean the inside window - or elsewhere in the interior - which would cause this sort of damage. |
(Post 1601616144)
Yike.
(Post 1601616122)
I have used Magic Erasers for many years on my autos and on my leather interior.
Consider the warning on the product: Test a small area with light pressure before use. Not recommended for the following surfaces: high gloss, polished, dark, brushed, satin, faux, bare/polished wood, copper, stainless steel appliances, nonstick coating, or vehicle body. Do not use on skin or other parts of the body. Using on skin will likely cause abrasions. These are all things which can be damaged by an abrasive which will scratch the surface. In particular, consider the warning "Using on skin will likely cause abrasions." Of course it will, it is an abrasive!As an abrasive, it will similarly dull your car's finish. Go out into your garage, try it out, and report back. We will wait. :) Look up melamine foam and how it works for more information. |
It looks like something ate the top layer of vinyl in those spots. I don't think that can be repaired but it might be worth while to find out if a Vinyl Doctor can fix it without removing the windshield.
Bill |
