teamo |
06-15-2020 12:07 PM |
transmission cooler line install
Trying to install my new pre-bent transmission cooler lines.When I removed the old lines they were all bent out of shape so I couldn't reference them for the new lines. The only clip that I see in the AIM is on the forward part of the frame underneath the lower control arm that uses a single bolt. When I removed the original lines there were two clips but they weren't bolted into the bottom of the frame so I don't know if they were correct. I've looked up new clips at several of the vendors sites and they seem to show two clips also. Do these lines get a single large clip with one bolt or two separate clips? Also there is a double bracket that is attached to one of the oil pan bolts. Is the bracket on the oil pan also for the trans lines? I can't find it in the AIM but it was on the oil pan when I removed it. Thanks
