Performance center engine plaque
Hello all, Been absent from this site since 2008 because I no longer owned a Corvette. Sold due to very bad luck ( Long story ) Things have finally gotten better and I recently purchased a 2020 Chevrolet Camaro SS with the 1LE track package. Not a Corvette but it does have a Corvette heart ( LT1 engine ) In fact the purpose of this post is to discuss this Corvette heart.
While working on the car I removed the driver’s side fuel rail cover and found a metal plaque attached to the lower corner of the intake manifold cover from the Performance Build Center Bowling Green Ky. From the research I’ve done so far this means that the engine that bears this tag was assembled by hand at the Corvette factory in Bowling Green. From what I discovered this type of build is usually reserved for the LT4 and LT5 engines that are installed in higher end Corvettes and also the LS7 engine that was installed in the Camaro Z/28. This plaque is also showing up on a few of the Camaro ZL1 with the LT4. My question is does this plaque come on the base Corvettes with the LT1 engine? Thanks, Keith https://cimg8.ibsrv.net/gimg/www.cor...e9f5ef51a.jpeg https://cimg6.ibsrv.net/gimg/www.cor...bdec5e83c.jpeg |
No.
Originally Posted by X99HARDTOP
(Post 1601937480)
While working on the car I removed the driver’s side fuel rail cover and found a metal plaque attached to the lower corner of the intake manifold cover from the Performance Build Center Bowling Green Ky. From the research I’ve done so far this means that the engine that bears this tag was assembled by hand at the Corvette factory in Bowling Green. From what I discovered this type of build is usually reserved for the LT4 and LT5 engines that are installed in higher end Corvettes and also the LS7 engine that was installed in the Camaro Z/28. This plaque is also showing up on a few of the Camaro ZL1 with the LT4. My question is does this plaque come on the base Corvettes with the LT1 engine? Thanks, Keith https://cimg8.ibsrv.net/gimg/www.cor...e9f5ef51a.jpeg https://cimg6.ibsrv.net/gimg/www.cor...bdec5e83c.jpeg https://cimg1.ibsrv.net/gimg/www.cor...54819e82c5.jpg |
IF, there is one, it will be under the driver fuel rail?
A plaque like that one is not on my LT1.
It's on my 2019 LT1 GS , drivers side under the fuel rail cover.
https://cimg8.ibsrv.net/gimg/www.cor...c2bef10563.jpg |
Originally Posted by franknbeans
(Post 1601939357)
Originally Posted by ftlaud1
(Post 1601938443)
It does not. I found the one on my 19 Corvette GS and relocated it so I could see it. I also found the person on my plate on FB. He retired from GM this year and we now keep in touch:) He wants to buy my car when I am ready to sell as none of his builder friends could ever locate a unit they built after leaving the plant.
https://cimg1.ibsrv.net/gimg/www.cor...54819e82c5.jpg Keith |
Mone does not have one.
2017 GS. |
I'll have to check mine and see if it has one.
(Post 1601940740)
2017 GS. |
I "think" it's on the 2020 Corvette since the engine is exposed. Read something a while back about it being added to show appreciation for the engine builders.
(Post 1601940703)
That’s really cool. Thanks for sharing. Hey the next time that you speak with him could you ask him when they first started doing the hand builds and tagging those engines? Thank you so much in advance.
Keith |
(Post 1601938443)
learned something new today!!! 2019 Stingray, built by Andrew Cline!!
https://cimg3.ibsrv.net/gimg/www.cor...db1aa5197f.jpg |
I too just reached out to my builder, pretty freaking cool honestly.
(Post 1601941448)
Here is the answer : The Performance Build Center started in 2005 in Wixom,Mi. They built several different engines. It was moved to Bowling Green in 2014. At that time they were building LS engines, expanded with the new LT engine in 2016 and earlier models had to order the Z07 option package to get a hand built engine. If It didn’t have a Z07 option, the engine came from Tonawanda NY. In 2017 the PBC was given all Z06 engines. From then on, all Z06 and ZR1 cars were PBC engines. LT1 engines were added, but in small numbers, but I believe the engine plants were at full capacity. At some point, we got all LT1 manual transmission cars.
Here is a pic of your engine building teams from Bowling Green : Hand-building teams
https://cimg4.ibsrv.net/gimg/www.cor...3d374d76b7.jpg https://cimg6.ibsrv.net/gimg/www.cor...e8bc42e37f.jpg https://cimg8.ibsrv.net/gimg/www.cor...6439ec3339.jpg single “perfect” engine is a huge feat. Because of the sensitivity of the torque guns & machines, this takes concentration, dedication & a little luck. Members of the exclusive “Perfect 10” Club at #BowlingGreen have successfully built 10 perfect engines in a row! |
Thanks to everyone who replied! Very cool
