Dewitts standard radiator on supercharged cars
Just found a crack in my radiator and am contemplating upgrading the replacement to the Dewitts radiator without EOC. My car is currently not supercharged but plan to add an A&A kit in the next year or so. Do I have to use the short dewitts radiator on a supercharged car or will the standard sized dewitts radiator fit? If it won’t any issues running the short radiator on non-supercharged car?
you can lay the stock size radiator down a little to clear a 3-4" intake pipe - so no issues really there... The cut down just lets you keep the radiator in the stock location...
No issues either way - just preference. |
Great thank you. Any issue with stock fans on the cut down radiator?
I do not have the cut down - I believe Dewitts has a nice dual fan setup that is setup specifically for the cut down.
