Looking for a front wheel for a C6. Does anyone recognize it and/or have one for sale
Hello all!
Can anyone tell me which model Vette this wheel is originally off of? These wheels are on my 2012 Lt1 since I bought it. When I bought the car, the dealer that told me that they were from a C6 Zo6 and were OEM. I am now being told that they may not be OEM and could be c6z replica wheels. I need to find a matching front wheel? Does anyone recognize it and/or have one for sale? I belive the front wheels are 18 x 9.5. Thank you all in advance for your help and advice! https://cimg8.ibsrv.net/gimg/www.cor...31f3c7af87.jpg |
Looks like Comp Gray. That's what I have.
send a message to HOUSEOFWHEELS
he might be able to source you the rim you need. on his site it looks like he has gloss black or chrome. not sure about painted like yours. http://www.houseofwheelsonline.com/corvette_copies.php Good luck |
Originally Posted by ETPhoneHome
(Post 1603214201)
Originally Posted by kliph
(Post 1603214181)
Just watched your YouTube video of your GS. The wheels look like they are the same color for sure. Love your car! It is definitely Bad Ass bud!!! |
These are 2006-2008 double spoke c6 ZO6 in competition gray
Bob House of Wheels 561-445-7606 |
Originally Posted by HOUSEOFWHEELS
(Post 1603215938)
Originally Posted by D-Dub2013
(Post 1603217794)
Originally Posted by Nick416
(Post 1603217821)
Thank you! That's definitely the one!!!
Hold on, are we sure this isn't a replica? I see base brakes so I am assuming this is not a Z06. If it had an oem Z wheel on a base front, wouldn't the wheel stick out past the wheel well??
I would pull a wheel off and look at the inside of the spokes. There will be writing telling you the wheel specs, and you will see if its oem or not. |
Originally Posted by Juniorss
(Post 1603219736)
Originally Posted by mcandrew67
(Post 1603219977)
:iagree: Your pic shows you have a Z06 sized tire on the wheel, 275-35-18 if they were Z sized wheels and offsets your tire would be outside the fender without wide fenders. I would say it is an aftermarket wheel with narrow body size/offsets. If you buy the OEM z wheel you will not be happy.
https://cimg8.ibsrv.net/gimg/www.cor...25a43b4869.jpg |
(Post 1603219736)
(Post 1603221209)
A Z06 size 18x9.5" fits the front of a base just fine, but just can't use Z06 size tires. I run a Z06 size up front and works just fine with a 255 tire. But yes he could definitely check. Pull the wheel and it should have a Speedline label stamped on the back inside of the wheel. But even it is not OEM he should probably measure it.
(Post 1603220017)
It is an LT1 base. The tires sit flush with the factory base fenders on the front. I have the extreme wide body quarters on the rear so the tires are really set in without using spacers. (picture of it below)
(Post 1603221507)
I dunno man, your tires look like they are outside the fender in that pic to me. I ran z06 fronts and tires on mine at one point when I had just the rear widebody and they stuck out. If you take a pic head on from the front, I am sure you will see they do stick out.
1 Attachment(s)
Here is what happens if you try installing OEM GS / Z06 wheels and tires on a Base C6:
Attachment 48338391 |
Originally Posted by Turbo6TA
(Post 1603221629)
https://i.imgur.com/OoqWQ0J.jpg |
