*** NEW *** C5 LED Bi LED HEADLIGHT Projectors @ JWM!
Most new oem headlight systems now include LEDs for both low and highs. You can now get that same light output on your C5! With our newest headlights, the standard projector has been replaced with a high quality Bi-LED projector that can instantly switch to the high beams via moving a cut off shield. This will enable the high beams to activate within milliseconds. The LEDs are instant on, so no long warm up time as with the HID kits of the past. These headlights from JWM offer OEM style crisp cut off lines. These will light up everything on the the road ahead of you without blinding oncoming drivers! The Bi-LED projector is encased in a weather tight, silicone heat-resistant, and flexible housing that protects it from exposure to the elements. $695 shipped for the set! Order here <---- https://www.corvetteforum.com/forums...sandled005.jpg
Add some HALO LED TAILS to your order to save an additional $30! Both headlights and tails must be added to cart for savings. No code needed! Order your set here <---- https://imagizer.imageshack.com/v2/xq90/923/tEFavY.jpg https://imagizer.imageshack.com/v2/xq90/923/YLNGZi.jpg https://imagizer.imageshack.com/v2/xq90/923/bfviqV.jpg |
What type of led bulbs are in the housing ? Can i buy just the bulbs from you if I have the ACA housings already ? Thx
Originally Posted by OUTAKTRL
(Post 1605293946)
Can you recommend led’s similar to the ones built in to the ACA housings please
Sorry, none of the plug n play leds that I'm aware of will be bright enough for the older housings. We've found the best results with 55 watt HID kits.
Currently stocked up on both! Who needs more light from their C5??
Rob your order shipped yesterday. Let us know how you like the new light!
Last day of the month bump!
Have a great holiday weekend everyone!
Back from the holiday and ready to ship some parts! Thanks everyone for the business.
Need to upgrade lighting on the C5 but can't decide between HID and LED.
Do these LED lights create glare against fog or rain? Foggy farms around me and I daily drive this car so glare is an important factor. |
Replying to the thread so I can find it again later.
Originally Posted by imma_stocker
(Post 1605365414)
WHo needs headlights??
To the top!
Many units in stock! Thanks for the business.
To the top!
600.00 for set!!!!!!
Originally Posted by LUV2SPD
(Post 1605443331)
$695 shipped for the set! Order here <---- |
