LT1 engine internal
LT1 owners.
I found a flaw on 2 OE. LT1 engines. The composite distributor stub developed stress cracks both sides of the arm. I currently made a proto type aluminum version to eliminate UNscheduled DISassembly. Before dropping my 383 perfecting my 2nd admiral. Gauging if any LT1 owners would like to eliminate this possibilty. if I make a batch. possible production. Thank you in advance. https://cimg7.ibsrv.net/gimg/www.cor...c6bc5c8fe3.jpg OE https://cimg2.ibsrv.net/gimg/www.cor...5f905e97ea.jpg Proto fit test. |
There is interest here....
Take a look at this piece👍
https://www.tickperformance.com/tick-performance-billet-aluminum-oil-pump-drive-housing-for-gen-2-gm-lt1-v8-engines/ edit: first link posted was an error page. |
Nice find. Thanks. I thought I had this market covered.
I designed my version a few years ago. Just fabed up test fit 2 days ago. Last stage bore shaft depth. |
Originally Posted by THE 383 admiral
(Post 1605438691)
Just for you old LT1 guys. The oil pump drive for a Gen7 8.1L truck that was made from 2001 to 07 uses a all metal drive that will work in the old LT1. Its a gm part number 12568356
No sir. Moving forward. Mine is replacing my OE composite, I did not pay $150. Best part is I made it. I seriously looked in the past. I did not find TP. They must be new and recently released this stub housing. Thank you gent's.
