94 Corvette very rough ride (like riding on wooden wheels)
I really love the way this car looks but I hate the way it’s treating me right now. Every time I hit a pothole or a dip in the road it’s really loud andPassenger rear tire pulls inward when I hit bumps and debris. It also has something loose with the rear drive shafts like I was told they need new u joints. But it feels like one side is bent ( halfshafts) because it noticably wobbles at 5-10 mph. I know I can let out air pressure out the tires to help the roughness issue.
my main issue is this kill is trying to kill me on the highway, going 65 and letting off, it literally threw me into another persons lane.and accelerating almost threw me off the road… I don’t want to die🤦🏻♂️😆… anybody with the best knowledge, please help 🙏🙏🙏 I still love this car but if heavy rain is present… nope I’m calling in sick that day. thanks anybody for you experience wise ideas and thoughts to help me out… |
1. Quit driving it. Put it up on jack stands, Grab the wheel(s) at 6 and 12 and see if there is any significant play in the bearings
If not, Then take off the wheels and start looking for the bad part. Pushing, pulling, prying, you should be able to find it. or if you have no mechanical ability, 2. Quit driving it. Take it to a garage. It could be anyone of the components wore out back there. Most folks don't have x-ray vision to see the car and it is hard to diagnose when it could be any of the rear suspension components. |
If you know your half shafts are bad you must replace them. They are an *integral* part of the suspension, unlike most cars. If you were to remove one the wheel would rise up and tilt inward as far as it could go.
If truly there is significant half shaft play (and not something else loose) fix it! |
Agreed Park It and inspect, as mentioned tug all around the wheel ends then move inward Tie rods ends and middle mount point, camber Cams, look at all the mounting bushings including Batwing mounting.
so all those parts you mention are all related to the rough ride like a flint stones mobile?
[ QUOTE=s carter;1605909255]Agreed Park It and inspect, as mentioned tug all around the wheel ends then move inward Tie rods ends and middle mount point, camber Cams, look at all the mounting bushings including Batwing mounting.[/QUOTE] |
Is the rough ride is it a new development in a car that you have been driving for months+ and now ride quality is Now Out the door. Really Dead shocks makes it much easier to hit bump stops and can greatly effect handling. All the parts suggesting to check are the things that could allow wheel geometry too wonder
well said carter.
The shocks don’t look very healthy. Old as the car. And I will fiddle around with all the other stuff too👍
Originally Posted by s carter
(Post 1605909829)
Originally Posted by drcook
(Post 1605909211)
If not, Then take off the wheels and start looking for the bad part. Pushing, pulling, prying, you should be able to find it.. |
These are not new cars anymore. For issues like what's been described, there are a number of things that could be the cause so go through it thoroughly. Check the hubs, u-joints, bushings for starters. Assuming you can do the work yourself, that's not a large investment to replace them and should definitely improve the handling of the car.
Good luck. |
