C8 Convertible Noise
Noise from behind Drivers Head. Sounds like loose bolt driving down road, Suspect Top problem because noise goes away when top down.
Haven't had that issue. I'd suggest letting the dealer look at it. That's what the warranty is for.
Does the noise go away with just the rear window down?
Originally Posted by Red Mist Rulz
(Post 1606035839)
Try a different dealer?
That's what I planned if GMsays OK. Thanks Fank
As someone above posted, try driving with top up and rear window down. If the noise goes away, you have your culprit. I think I remember an old post discussing having to put some lubricant on the edge of the rear window to keep it from rattling.
Other than getting a louder exhaust or radio… maybe try to get a friend to drive and use an automotive stethoscope with and without an open tube to narrow it down to an area or a panel, mechanism. It could be a harmonic caused by wind buffeting only at certain speeds which is even more annoying. With the complexity and ability to govern you speed that this top mechanism has, I would not ignore it and would not go to the dealer again without some new information.
Don't forget the snap on the little buckle that holds your seat belt. At the top of the seat.
Driving with the top up I had that rattle. Top down it was gone....
Took it to the dealer and it was fixed the same day. Apparently it was a fastener that came lose in the bulkhead of the folding top. Problem solved..... (You need a different dealer.) |
I had to put some GM grease on the window. Problem solved
Originally Posted by RKCRLR
(Post 1606035846)
Originally Posted by flittlejr
(Post 1606035380)
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement. Privacy Statement | General Motors Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information. www.gm.com |
