Rear Tire Losing Air on my Grand Sport, Cracked Wheel?
This morning one of my rear tires on my '19 Grand Sport was down to 13 PSI. Oh wonderful! Filled it back up and seems to be holding while driving. But stopped for breakfast for around an hour and it was low again. Have Bridgestone Run Flats. As far as I can tell I can't see anything in the tire like a screw or such. But I did hit a big deep manhole cover on a road yesterday, so hope I didn't suffer the dreaded Grand Sport bent or cracked wheel. So off to the dealer tomorrow. Good thing I got wheel and tire protection when I bought the car. So stay tuned.....
Could be. Have it checked out. :yesnod:
Damn :(
You might check the valve stem for a leak with soapy water. Either way, at least you are covered! Good Luck. :cheers:
Originally Posted by Vette Jockey
(Post 1606179099)
The cracks that develop on the inside of the rim are pretty easy to see... at least mine were. Soapy water confirmed the air loss.
Originally Posted by JosephMingle
(Post 1606179229)
FYI: Cracked wheels can
https://cimg8.ibsrv.net/gimg/www.cor...c8708f7d02.jpg https://cimg0.ibsrv.net/gimg/www.cor...adbd842bf9.jpg be fixed! |
Good luck at the dealer. Hopefully it turns out to not be a cracked or bent wheel.
Take some soapy water and start spraying the wheel. The bubbles will show you the leak which is probably a cracked wheel.
Originally Posted by Ron_Attleboro_MA
(Post 1606179530)
https://cimg8.ibsrv.net/gimg/www.cor...c8708f7d02.jpg https://cimg0.ibsrv.net/gimg/www.cor...adbd842bf9.jpg be fixed! I personally wouldn't have repaired it. I'd much rather new wheels. |
Let us know how it went
You can also take your car to a shop like Discount Tire (America's Tire in California) and they will remove the wheel and test for leaks. The last time I had a tire pressure problem I asked them to specifically look for a cracked rim which they unfortunately found was the problem and then remounted the wheel. No cost. Being the second cracked rim I had I then replaced all the wheels with non-GM.
If its bleeding air that fast, its probably very bent and cracked, or the tire has sucked up a nail
Update, heard back from the dealership. Looks like I have joined the Cracked Grand Sport Wheel Club! They just ordered a new one. Definitely thankful I got the Tire and Wheel coverage when I bought the car.
Glad to hear that! I mean the part about getting it replaced via the coverage. Keep doing that with each wheel as it breaks and get some real wheels when the coverage expires. A little inconvenient, but since you paid for the coverage take advantage of it. Have a good one.
Originally Posted by bassmobile
(Post 1606178699)
I'm still waiting for the third wheel from GM. From September. |
Originally Posted by owc6
(Post 1606185783)
Good luck with that.
Well just got her back. Guess they have a good stock of wheels in anticipation of them cracking!
https://cimg0.ibsrv.net/gimg/www.cor...6b2a38f7d.jpeg |
As long as we buy these GM Chevrolet with wheels...gonna be problems.. They should sell em With Out the wheels fitted to their GM product ... then we go find WW.......... Wheels that Work.. since they can't!... Come on Mary! Yeah, we'll help you GM... as usual, we bail you (GM) out.
