Npp vacuum hose
Hello all, I pulled the fuse for npp and the usual service traction and active handling appeared.fuse back in all goes away.
Besides getting a npp controller can you just pull vacuum hose from exhaust valve and plug up therfore valve stays open? Commonly used for Porsche and others. Sharkworks exhausts even send plugs when getting their systems |
I've never heard that in the 10 years I've been on here. Why do you say it's the usual codes? I'm perplexed, but that's common...
I believe you can remove and cap off the small hose on the back of the intake manifold and they'll stay open. At least that's how it is with my Z06, had to reroute that hose with the MSD manifold.
Yes, pulling any fuse will usually cause a code. I meant pulling vacuum hose off of npp valve in back and plugging up hose to prevent debris going in. Solenoid won't even know thus no codes and wide open valve. Done many times on 911 Porsche
Originally Posted by corv1998
(Post 1606260307)
Great, thanks makes sense to block off up front.
I plugged the port at the intake manifold myself without removing the manifold from the engine. Here is a thread describing the process. If your hands are larger than medium-sized, you probably won't have enough room to do it.
"I pulled the fuse for npp and the usual service traction and active handling appeared."
If it's like a ZR1 then I'm guessing you pulled the wrong fuse. I've never heard nor experienced that issue and I've pulled the NPP fuse many times....never once a dash light or message. :nono: |
Yeah you shouldn't get a code from removing the NPP fuse. Many people, myself included, have a switch that essentially disconnects the fuse when we want to run the valves open all the time (same as removing the fuse) and never throw a code.
I agree with others here, that pulling the fuse shouldn't cause any codes, so thinking you pulled the wrong fuse. I never had any codes when I pulled the fuse. It is the red #10 fuse on the lower right fuse panel in the passenger floor board.
https://i0.wp.com/cimg8.ibsrv.net/gi...resize=650,400 |
(Post 1606257375)
