How can I tell if Transmission fluid has been change
I bought a 2017 base Corvette automatic about 8 months ago. It had about 20,000 miles on it. I now have 25,000 miles on it now. I have been reading about the transmission triple flush. How can I find out if it has been done on my vette. I bought a range technology box the first week and I never experienced any problems with the transmission rough shifting. Should I just have it done for peace of mind.
I purchased my Stimgray in February of 2022. I got a carfax report which told me of all the service history. Also check with dealer. They may be able to run your VIN and have a service history
I buy a new to me car, IOW, used car, I follow a simple plan. If it flows, it goes. I don't know what you did or didn't do, whether you used quality materials or something from some dusty shelf or if you even did it.
Open an account on Chevrolet.com and you can see any maintenance done at a GM dealer.
Ron |
RonC7
Thanks for the information. I had an account with Chevrolet.com and when I logged on the Vette was not on it. I added the vette. The vette had nothing listed under Service History. I bought the car from Carvana so that might have something to do with it. I did find my Powertrain limited warranty expires on 5-8-2023. My question is can I have this procedure done under the powertrain warranty free. |
Originally Posted by hawkandersonjr
(Post 1606347727)
Chevy may have lost your VIN's data during an update. Info on my 2014 Z51 disappeared in 2017 or so. Info on my 2014 GMC is still available in the system.
Any GM dealer service department should be able to pull up the GMVIS (also apparently called IVH) report for you by VIN. Ron |
You can check maintenance records or consult with the previous owner. Alternatively, you could inspect the fluid color and condition yourself or have a mechanic do it for you. If you're uncertain and for peace of mind, it's advisable to have the transmission triple flush performed.
It never hurts to just change it. If you can do it yourself, not that big of deal. I have a 14 3LT, changed all the fluids, like he said, you never know what someone put in the car, lots of snake oil people believe in. Even the oil filter is important to get correct.
Especially at that mileage I would also just go ahead and change it.
It sounds easy to just change the fluid, but husband says the gasket needs replaced too as that is normal procedure when changing fluids...and THAT is the scary part for me- because the transmission has to be lifted a bit to get to the pan- correct?
How CAN you tell if fluid has been replaced? is there a color difference or smell or anything? My husband is an experienced (40 years) aircraft mech so he knows what he is doing but if we can be assured that the flush has been done that is better. 2017 GS 8AT 18k |
Originally Posted by aklim
(Post 1606347211)
Originally Posted by Blackcherry20
(Post 1607768183)
(Post 1607776505)
I think you have to flush it 3 times so it is about 4 hours with 20 some quarts of fluid or in simple terms $1000 give or take a few hundred.
(Post 1607776901)
It’s def a time and money commitment… may be easier to take it to a dealer but I have a mistrust there. So I wait for hubs. Ty for the reply @aklim
I believe it is 3.8 hrs and 24 quarts of fluid. So if you are getting someone to do it, DON'T just take a number. As my math instructors used to say "No working, no credit.". Show me how you came about that number with the hours and fluid. IIRC, those are the TSB numbers so it can't be below that since that is what GM would pay under warranty which is sometimes less than what you would pay. Ask what the hourly rate of the shop is and multiply it by 3.8 hours. Ask the parts department what the fluid sells for and multiply it by 24. Add both and see how much it should cost. All the Service Advisor is good for is to tell you the labor rate and get an appointment. You need to find the Corvette Certified tech first and talk to him.
My SA lied to me. We were doing some updates so I backed off the tunes. I told him NO TCM or ECM updates. Later on, he called and said he had a deal for me. 3 updates for the price of two. I asked which three. TCM was one of them so I told him not to do it. Later on, he charged me for 2 and said that although the paper said TCM, he didn't do it. Talked to the tech who confirmed that it was done. No biggie but tech gained a bit of trust since he told me the truth and I will never use that SA again. To the tech's credit, he did try to call me but I was not able to answer. Trust BUT VERIFY. Disclosure, it was a spur of the moment thing so I didn't get to talk to the tech directly that morning since he came in later. |
If you can DIY there's a good thread HERE that explains how to flush with 12 quarts including the coolers and torque converter.
Originally Posted by hiltsy855
(Post 1607782328)
Yes. I separated the line at the rear cooler and started the engine for a short time, using the transmission pump to push about a quart of fluid thru the system. Add a quart then rinse & repeat 5-6 times. The new fluid pushes the old fluid out.
Id just change all the fluids, filters and call it good
