Dewitt's Direct Fit W/17" Single Fan
Just yesterday I installed this combo in my C6 Z06 and man was this a tight fit. The fan is resting on top of the abs unit and after looking at DeWitt's website I don't see any type of mounting bracket for the upper radiator support. I happened to come across these mounting brackets and hopefully they can push the upper radiator foward off of the abs unit. CPR C6 Radiator support brackets - Cordes Performing Racing (cordesperformanceracing.com)
I'm sure there are some members here running a Dewitt's radiator and would appreciate some input on how you are supporting the upper radiator. The 17" SPAL fan also came with a temp sensor to tap into the radiator hoses what would be the best location for this? https://cimg8.ibsrv.net/gimg/www.cor...decca1b4cc.jpg https://cimg5.ibsrv.net/gimg/www.cor...f78e9d4c8e.jpg https://cimg6.ibsrv.net/gimg/www.cor...2b8c3ccc6d.jpg |
Basically you need to move it to the other side - passenger or it could hit the ABS. They make a passenger side fan shroud. It needs to be moved over like this - metal one. There is a lot of stuff going on the drivers side less on passenger side. I am using the Spal plastic shroud they sell for that fan here is a photo of that also. On the upper hose is where I install the PWM and Dewitts sells a metal hose adapter coupling you put it in between the lines. I guess you could try flipping the shroud upside down to move the shroud to the passenger side but I think the big shroud hook is on the top side so that might not work. The fan needs to be like 2 inches offset from center as can be seen in photo above.
https://cimg1.ibsrv.net/gimg/www.cor...8b3340629f.jpg https://cimg3.ibsrv.net/gimg/www.cor...cc6cace036.jpg https://cimg4.ibsrv.net/gimg/www.cor...3286876373.jpg |
Use the ecu to control temps not a sensor
Originally Posted by double06
(Post 1606463726)
Originally Posted by Apocolipse
(Post 1606463777)
I have the cordes upper rad mounts. It doesn’t allow for much adjustability forward or back, but it’s a nice unit and more supportive than the factory. Wasn’t my main reason for ordering it but I hoped there would be more adjustability. I also have a LG rad not Dewitt’s, also stock fan.
Originally Posted by Captain_Insano
(Post 1606464456)
idk if doing that will affect the full use of the fan. It has different speeds for different temperatures.
The stock fan is also moved over to the passenger side to miss the ABS unit.
(Post 1606463726)
I do not have the part number of the passenger side shroud they may have stopped building it but they have had it (about 5 years ago) so I wonder why they do not make it now. Now what you could do is flip your current one over so it is on passenger side and the old top part had a lip make a piece out of aluminum to bolt to top of old bottom piece so now it has the lip like the old top part. The top lip holds the shroud in you just need to make a new one for the new set up. On the rubber flaps you will need to drill holes so that you can flip the flap so they are opening like they were before (but since you have flipped it around they are upside down now - I think they might be 1/8 holes but check). My plastic shroud I got from them is a 32-sp080.
