Best caliper paint?
I am going to paint the brake calipers on my 2023 Jaguar F-Pace and looking for recommendations on the best paint to use. I do NOT want to spray paint them unless that is absolutely the VERY BEST BY FAR option. (They will be painted bright red if that makes any difference.)
Recommendations, please. TIA! |
G2 Kit at TireRack
http://www.tirerack.com/brakes/acces...um=G2160&ID=41 This is a two part paint with paint and a hardener. It's a high temperature epoxy paint that is very tough. Once painted on the caliper it "flows" to hide any brush strokes and ends up with a beautiful gloss finish. Get a set of small artist bushes because the one in the kit us useless. Mix up half the paint/hardener and do two calipers and when done with them mix up the rest and do the other two. No need to remove the calipers from the car. https://cimg8.ibsrv.net/gimg/www.cor...38f3c54780.jpg |
That stuff is awesome. My son used it on his Mustang calipers and they looked brand new OEM.
I used the Dupli-Color caliper paint kit on my MR2 years ago & they still look like new.
It comes with everything....a cleaner, stir stick, brush...:thumbs: |
I did these calipers literally with Rustoleum rattle can paint. One $6 spray can did all four. I hand painted the raised red.
This pic is 2 years old on the black caliper paint. You really don't need to buy into all the paint hype for calipers. https://cimg9.ibsrv.net/gimg/www.cor...65b86dff09.jpg |
Check out TPS Motorsports. You can get calipers powder coated whatever color you want. This might be a better option.
TPS Corvette C8 Powder Coated Brake Calipers (tpsmotorsports.com) |
Duplicolor worked great!
Update: Than you all for posts/suggestions.
Opted to go with Duplicolor (red) and very happy with results. One recommendation: buy additional brushes. The brush that comes with the kit is useless after first use…paint makes it hard and useless for a second (or more) application. And get some small detail brushes for the tiny parts. Cheers! |
