RPM Transmission 2005 C6 Corvette Performance Upgrade Differential
*0% Financing for up to 2 years (Ask us about it)
*Layaway Available (No Credit Needed!)
*Free Shipping to ANY address in the USA!
Do you have a 2005 Corvette and want to upgrade or replace that piece of glass GM put into your 2005 Corvette? RPM Transmissions is the leader in drivetrain upgrades for Corvettes amd has has done it again! With the RPM Transmission 2005 C6 Corvette Performance Upgrade Differential you get a upgraded 06+ differential which will for your 2005 Corvette
RPM Performance Upgraded Diff
TPS offers this must-have upgrade for those of you that wish to get that neck-snapping acceleration that only a lower gear change can deliver! Units are purchased on an exchange basis. Each differential performs OEM quiet guaranteed and make no mistake; TPS with RPM offer the best built, most durable and strongest Corvette IRS differentials available! They are built with quality and durability in mind as an engineering target, not just price, as you deserve nothing less than the best for your high-performance Corvette. Give Us a call today to get the Best Built Diff for your corvette.
Click here to place your order
So what does a TPS RPM DIFF offer?
Stage 2 Package
-Media Blast Transmission Case
-Stronger 2006+ Style Assembly
-Seal & Gasket Kit
-C6 Z06 Left Stub Shaft
-C6 Z06 2-Piece Right Stub Shaft
-OEM Clutch Packs
-HD Preload Springs
-Performance Metal Micropolished Ring & Pinion
-Adapter Plate Kit
Stage 3 Package
-Seal & Gasket Kit
-300M Left Stub Shaft
-300M 2-Piece Right Stub Shaft
-OEM Clutch Packs
-HD Preload Springs
-2.56, 2.73, 2.93, 3.42, 3.73, 3.90, 4.11 Ratios Available
-Adapter Plate Kit
Stage 3 Package
-Seal & Gasket Kit
-C6 Z06 Pinion Support
-Wavetrac Differential
https://cimg6.ibsrv.net/gimg/www.cor...56705abbb.jpeg
