Wiper arm removal
Both wiper arms are totally seized. I tried this tool but it's a no go because the bottom part won't fit under the arm.
Removal Repair Tool. Does anyone know a tool that will fit a C5 to remove the wiper arms? Thanks |
Buy Kroil - spray wait 5 mins and try again.
I used wd40 and it eventually came off
I sprayed it with WD40 a few days ago.. I'll look for Kroil at Autozone.. it's been raining so i'll try again in a day or two. Thanks for the suggestions
I used PB Blaster and this puller -- I won't say they came off easily, but they did come off. You might want to take a couple of photos and perhaps make a pair of match marks to get them aligned the same on re-installation.
Redzg,
I appreciate your reply, that is just what I was looking for, they should arrive tomorrow. Good idea about preparing for re-installation, I didn't think of that. I'll post about what progress I have with these. Have a great day |
You did take the 1/2 nut's off first right? I only ask because the first time I try to remove mine I did not know about them.
yes the 1/2 nut's are off. Even with the tool Redzg suggested and PBlaster they are still seized on. I was trying to see underneath where it connects if there is some kinda button or something i'm missing. This sux because I can't change the windshield cowl without getting the wiper arms off first. I put more PBlaster on and i'll try again later.
edit to mention that the tool Redzg suggested only fits the driver side arm.. only half of the tool will fit to grasp onto the passenger side wiper arm. |
No sneaky parts. Just the cap, a 13mm hex nut, and the arm.
I watched a half dozen youtube vids to see if anyone shows a recalcitrant arm set, but they all either just skip showing the arms coming off, or show it being a piece of cake. great I do want to verify that you have the arms lifted to the detent position while attempting removal, yes? I'm sure you do, but have been bit in the ass by simple things in my past. If the blades are against the windshield that would apply an offset preload to the splines. No beuno. When all else fails, the answer is usually heat. Now, how to apply heat to the end of the wiper arm without inducing risk to other components -- such as the cowl panel -- is a good question. Mine argued too. There may have been multiple applications of both PB Blaster and my most effusive collection of four letter words. You might also try freezing the shafts. Just as heat would expand the arm spline rings, cold would shrink the shaft and splines. New cold spray isn't as good as old cold spray, but it still gets cold. |
Success! today both wiper arms came off by using the tool Redzg suggested. it took just about maybe 10 pounds of pressure pulling up while the tool was on and they popped off. Here's a picture with the cowl off. Now I can clean under there and attach a new cowl that i bought a while ago. Thank you all for your help, I couldn't have done it without you guys.
https://cimg4.ibsrv.net/gimg/www.cor...cf41e2f297.jpg |
Glad it worked out for you! Tool works very well on post style battery terminals too -- though I have never had those stick nearly as bad as my wiper arms did.
I was able to pull mine off after a little penetrating oil and some furious wiggling.
Originally Posted by greenscobie86
(Post 1607638695)
Originally Posted by redzg
(Post 1607639544)
Garaged or driveway kept car? I imagine those of us who keep the car in the drive are going to have the most trouble.
(Post 1607639544)
