1961 Posi Rear Drum To Drum 3789812
1961 Posi Rearend #3789812 Date Code L91 and numbers on passenger side L1220 Asking $1500.00
https://cimg0.ibsrv.net/gimg/www.cor...cae3117b29.jpg https://cimg1.ibsrv.net/gimg/www.cor...dfc407dc2c.jpg https://cimg2.ibsrv.net/gimg/www.cor...55e4efe789.jpg 1961 |
Where are you located?
Rearend located in Canton, Ohio 44718
What's the ratio?
I will check, I got two in a purchase, this is the other one.
Spins a little more than 3.5 times when rotating so assuming it has the 3.70 gears, but I may open it up and count the teeth to make sure, rotating is a ballpark
Btt
Ttt
Ratio is stamped on the ring gear.
Originally Posted by fuely
(Post 1607773717)
