CORVETTE TODAY: Harlan, Tadge & Josh Answer YOUR Corvette Questions!
Guys, it's time for our 2nd annual sit-down with Harlan Charles, Josh Holder and Tadge Juechter during the NCM Michelin Bash.
These three will answer your Corvette questions! Please submit your questions in this thread. Please remember - the Corvette Team will NOT answer any questions about future Corvette projects. Those questions will not be submitted. So what do you want to know about Corvette? Now is your chance to get them answered, courtesy of CORVETTE TODAY. https://cimg5.ibsrv.net/gimg/www.cor...7d6c074cd2.png |
Do they know about the headlight issues with the "runs" inside the lens? We are seeing this on more and more cars (mine included) and we need to make sure that they understand what caused it, and that it is fixed for good if we have them replaced under warranty. Replacing them, to have it happen again, seems futile.
Edit: I was finally able to get the light right to take a picture of my headlights today. Both sides have the problem. For reference: https://www.corvetteforum.com/forums...ight-lens.html https://cimg3.ibsrv.net/gimg/www.cor...506dfeea3.jpeg https://cimg7.ibsrv.net/gimg/www.cor...540a08218.jpeg |
Why are the Jake hood graphic on Stingray and ZO6 and the Jake rear graphic not installed at the factory and you make the dealer install them? Not every dealer has a body shop to do this job?
Exactly how does the DCT filter life monitor work on the C8. Our understanding of the require maintenance is that the first replacement is at or near 7,500 miles. But when is the second change supposed to occur, at 22,500 miles, or 22,500 miles after the first change, which would be 30000 miles, and does the DCT filter life monitor correctly incorporate that requirement? Reports on the forum seem to indicate the filter life monitor will go 22,500 miles after the first change. So, is the filter life monitor correct, or must it be change at 22,500 miles?
If the car is connected to a local, internet enabled network via WiFi, such as an internet enabled WiFi in a garage, will it share data, such as smart driver data with OnStar via that connection? Or, is data only shared via the built in cellular connection?
And, related, will the car automatically connect to any WiFi network of opportunity, or will it only connect with the owner's permission? |
What, exactly, does the Hydraulic System Flush do inside of the transmimssion?
In the procedure for replacing the DCT external canister filter, after the filter is replaced, the procedure calls for a leak test that is initiated by a scan tool and takes about 1 minute. What does that test do inside of the transmission? |
Why is the Hydraulic System Flush required every time that the DCT external canister filter is replaced?
Anecdotal data and informal polls suggest that there's a valve body and/or transmission issue that could affect somewhere between >1% to 15% of C8s - what is the actual failure rate, and what is being done to improve the problem?
Additionally, what is being done to make sure that owners don't wait 30+ days for replacement parts? |
After four years experience in real world DCT, I am wondering if any consideration regarding frequency of DCT fluid change. Other vehicles using similar fluid and similar transmissions have much longer DCT fluid change intervals. The real question is why is DCT fluid Titan FFL-4 change interval DATE-BASED at all?
Examples: Audi R8 DCT fluid interval 40,000 miles not date based? BMW M3,E90, E92 DCT fluid is Lifetime but some recommend 50,000 miles Porsche 997.1 PDK fluid is 60,000 miles or 6 years. VW DSG fluid change 40,000 miles not date based. Ferrari 458 Lifetime? McLaren 12C 40,000 miles and not date based. |
Originally Posted by sowega
(Post 1607680290)
Originally Posted by RKCRLR
(Post 1607680487)
My bet is they don't answer those questions...
Originally Posted by gdb069
(Post 1607680477)
After four years with DCT I am wondering if any consideration regarding frequency of DCT fluid change. Other vehicles using similar fluid and similar transmissions have much longer DCT fluid change intervals.
For those of us that like to do their own maintenance, is there an acceptable DIY option for changing the DCT filter for those of don't have access to a GM MDI tool and subscription? For example, having our dealer perform the hydraulic system flush and then driving home to change the DCT filter ourselves?
Originally Posted by Andybump
(Post 1607680276)
What does the scan tool initiated transmission leak test do inside of the transmission? |
(Post 1607680545)
And what does the leak check after the filter change do?
Does 100% of the transmission fluid that is picked up by the pump flow through the DCT external canister filter. How long does it take for all the fluid in the transmission to be filtered?
(Post 1607680543)
(Post 1607680545)
(Post 1607680543)
So if I want to just change out my dct filter at 2k…….can I just do that without a leak down test?
Then at 7500 have my dealer do flush and filter. |
