Heater slide
Hi everyone. I am excited to be able to talk to others. I am just now starting to repair some items i'm sure you are pretty bored with. LOL
My first problem is my heater control slide on my 1987 C4. I have the stereo out and was replacing electrical tape with wire connectors. When I got done and replaced everything I found that the heater control slide (NOT the temp, but the actual control slide for the heat/Ac/defrost etc) won't move from the off position. Is there a wire I may have cut or pulled off? What makes it work? When I try to slide it I can see some type of diaphram move a hair then stops and it seems like it actually is starting the A/C because the engine starts to load. Can anyone help me with this? Thank you |
Welcome to Corvette Forum. Your post will be moved to the C4 Tech section. A lot of knowledgeable folks there.
The 'select' heater/AC/Defrost is a select rotary switch not cable operated. Temperature control is a cable. I expect you don't have a FSM(Factory/Field Service Manual) so I cant reference you to the sections you need to look at but I will post an image of the control and what controls it. I can help you with the FSM and when purchased from me I also provide a very good GM SPO Parts Catalog that you could use to research parts information for your car. You don't have sufficient posts so that I can message you but you might be able to PM or eMail me using the links to the left under my user ID.
In this image #3 is the Select Rotary Switch https://cimg9.ibsrv.net/gimg/www.cor...3b7317a65d.jpg |
Welcome
Originally Posted by WVZR-1
(Post 1607693652)
Originally Posted by Cruisinfanatic
(Post 1607695461)
Unless it electronic, it has a cable
(Post 1607695476)
I don't believe so and since the OP mentioned specifically 'mode' (heat/AC/defrost) that is NOT cable controlled.
(Post 1607695577)
Here's an eBay offering where even you should be able to absorb the fact that it's NOT cable controlled. Look at the select rotary switch! https://www.ebay.com/itm/31455805654...3ABFBM0sCFltdj |
(Post 1607695596)
What has that to do with anything? COLD ----------HOT is cable controlled but MODE/SELECT is NOT
Don't get upset Do you ever talk nice? Maybe you think you are chatting on Facebook? |
I do have the FSM but not the parts catalogue. Your pic is much better than my books. I believe I must have knocked a wire off because there is a red wire hanging about...I'll take the control out and look. Thank you.
(Post 1607695604)
Originally Posted by sdhfdon@gmail.com
(Post 1607696440)
https://cimg7.ibsrv.net/gimg/www.cor...4ba4a37ef5.jpg |
(Post 1607696833)
Nope! I know where I'm at and I'm very, very, very seldom seen on Facebook! Do you gots that?
