C7 Z51 HP problem..
Hello, I have a C7 z51.
With exhaust downpipe and X pipe. both without catalyst. KN replacement filter And a Tune. The truth is that the car works very well. I have done several tests against a friend's C7. and even mine is a little faster. Today I went to the dyno and I had a bad surprise. I expected 15 or 20 HP more than stock. Stock is 466hp "supposedly according to the manufacturer" . Well, I was thinking about 490 hp or so. The result was 442hp engine. and 317 to the rear wheels. with a torque of 585Nm Why so little power? It is normal ? The dyno is from the Maha brand. They are very prestigious. https://cimg8.ibsrv.net/gimg/www.cor...4bfcffdad.jpeg |
I have done the typical test from 40 to 100 MPH.
first in one direction of the road and then just in the opposite direction. I always get values between 5.6 and 5.7 sec. It seems like a good time. Is it possible that the Dyno is bad in this case? https://cimg7.ibsrv.net/gimg/www.cor...d1b3f5fbbc.jpg |
A dyno on a stock C7 is a little over 400hp at the rear wheels. So if you gained anything it would be around 420-430 at the rear wheels. Its 460 at the crank.
A stock NPP equipped C7 (whether base or Z51) is 460 crank HP. If you got a dyno reading of 442 crank and 317 rear wheels then yes, you have a problem.
:iagree:
confirmed the Dyno has a problem. I don't configure it correctly.
I have tried dragy. with the traction control on, 2 people riding and street asphalt, and I think it's not bad at all. You can improve the 0 to 60... by disconnecting the control and making a good start... What do you think of these numbers? https://cimg6.ibsrv.net/gimg/www.cor...f0db9b5f87.jpg |
