change oil light?
My change oil light came on, and I changed oil around 1,000 miles ago! oil level and pressure all seem good. How do I turn it off or reset it?
Re: change oil light? (MongooseLT4)
turn ign. on but don't start car. Press eng/met buttonand release then within 5 seconds press it again. Press and hold the gauges button light will start flashing then go out. You are done! :lol: :chevy
The Procedure is in you're manual. I got mine right here and i can't find it, but i know it's there i did it last year when my light came on. :confused: I better keep looking cause I'll need to know in a couple thousand miles.
:seeya There it is page 90 :lol: :iagree: [Modified by wz2wj1, 6:46 PM 4/22/2003] |
1. Turn the key to the "ON" position, but don't start the engine.
2. Press the ENG MET button on the Trip Monitor and release it. Then, within five seconds, press and release the ENG MET button again. 3. Within five seconds, of Step 2, press and hold the RANGE (1990-1991) button or the GAUGES (1992-1996) button on the Trip Monitor. The CHANGE OIL light will flash. 4. Hold the RANGE or GAUGES button until the CHANGE OIL light stops flashing and goes out. When the light goes out, the Engine Oil Life Monitor is reset. This should take about ten seconds. If it doesn't reset, turn the ignition "OFF" and repeat the procedure. |
Re: change oil light? (sumoboy)
Thanks guys :cheers: :seeya
