Bolt sizes needed
I need to know the sizes and lengths for the following bolts. Thanks for the info guys.
Valve cover bolts Intake manifold bolts Thermostat housing bolts Timing cover bolts Water pump bolts Header bolts :cheers: |
Re: Bolt sizes needed (desi)
Intake manifold
(12) 3/8 in. x 16 thread, 1 in. long bolts (12) 3/8 in. flat washers Valve covers (8) 1/4 in. x 20 thread, 7/8 in. long bolts (8) 1/4 in. flat washers Water neck (2) 3/8 in. x 16 thread, 1 in. long bolts (2) 3/8 in. flat washers Water pump (4) 3/8 in. x 16 thread, 2 in. long bolts (1) 3/8 in. x 16 thread, 1 1/2 in. long bolt (2) 3/8 in. x 16 thread, 1 3/4 in. long bolts (1) 3/8 in. x 16 thread, 2 3/4 in. long bolt (4) 3/8 in. flat washers Timing cover (10) 1/4 in. x 20 thread, 1/2 in. long, bolts (10) 1/4 in. internal lock washers Oil pan (14) 1/4 in. x 20 thread, 1/2 in. long bolts (14) 1/4 in. flat washers (4) 5/16 in. x 18 thread, 5/8 in. long bolts (4) 5/16 in. flat washers Fuel pump (2) 3/8 in. x 16 thread, 1 1/4 in. long bolts (2) 3/8 in. flat washers (2) 1/4 in. x 20 thread, 1/2 in. long bolts 2) 1/4 in. flat washers Header (12) 3/8 in. x 16 thread, 3/4 in. long bolts Special small hex Distributor hold-down (1) 3/8 in. x 16 thread, 3/4 in. long bolts (1) 3/8 in. flat washer Summit Racing Part Number SUM-56490Z $17.00 Zink Coated [Modified by 75stinger, 4:50 PM 5/12/2003] |
Re: Bolt sizes needed (75stinger)
What would I do without you guys. Unbelievable support.
Thanks. :cheers: |
