Largest Diameter tire that will fit 1995?
Without hitiing anything.
Re: Largest Diameter tire that will fit 1995? (cOvette)
Depends on wheel offset. There's a guy in my region that stuffs 335's under the rear of his LT4. He says he hasn't modified anything and only has minor rubbing under hard cornering. :confused:
Re: Largest Diameter tire that will fit 1995? (RM 4 TWO)
Thanks, but notice I asked for diameter, not width.
I autocross 315's all around with no problems, but for off road RallyCross i need an off road tire. |
Sorry:withstupid: I believe max is 19". Check TireRack.com or with "Todd@Tires.com". He's a forum member that works for Discount Tire. He can generally be found in the Wheels & Tires section .
[Modified by RM 4 TWO, 9:53 AM 6/4/2003] |
I have seen 20" wheels on a vette. Looked funny. 19" would probably be better and if you can afford don't go less than 18". Just my opinion.
Re: Largest Diameter tire that will fit 1995? (BAM92)
Thanks for the replies, but again, I am asking what is the largest TIRE (not wheel) diameter.
My ZR-1 has 345/35/18 Michelins. Is that tall enough for you?
Re: Largest Diameter tire that will fit 1995? (USAZR1)
USAZR1, What did you have to do to stuff 345 under there and what offset are you using? :eek:
The car has 18x12.5 OZ Mitos with approximately 34mm offset. The 345's fit fine on a ZR-1.
