400rwhp on N/a spec ...?
hey,
im getting my engine work done soon (in time for xmas :party: ) and i dont want 2 add a sc or nos just yet, is it possable 2 get 400 or 450rwhp only N/a Spec? (i know there is a c4 vette that has run a 10sec with n/a spec only) wat am i looking in price if i was 2 get it built? $10,000...? Thanks :cheers: |
Re: 400rwhp on N/a spec ...? (Soulja_350)
:D
Cost will get up there. If your having someone else do it add even more. Its not cheap to go fast. :cheers: |
Re: 400rwhp on N/a spec ...? (ski_dwn_it)
:D Cost will get up there. If your having someone else do it add even more. Its not cheap to go fast. :cheers: I'm doing a 383 now and hoping for the same #'s as you, I did none of the work myself, the engine is in the 10,000 range. That didn't include some of the things I already had, Long tube headers, 54mm throttle body, etc.. and some of the things that had to be purchased Accel DFI, new radiator, some suspension mods, etc... I don't want to total it up, but it better fly :smash: |
my 383 made 462 rwhp and i built it myself, and the costs did get up there, and now stupid me is building something bigger!!
Take the 10G'S and sell your car and buy a C5.
You can get 400RWHP with bolts ons :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: |
Re: 400rwhp on N/a spec ...? (mackeyred96)
:iagree: A friend did heads and cam on his formula and got 402rwhp. Makes me sick. :U
Re: 400rwhp on N/a spec ...? (87Z-ya)
i hope to have around 600hp flywheel, and i don't really want to know exactly how much i have into the motor etc now. (i know it's a lot) :eek:
:iagree:
If I swapped my cam to the CC306 I'd probably be there. I would probably go with a custom grind though.
Re: 400rwhp on N/a spec ...? (SonnyinVA)
600 fwhp takes BIG bucks to achieve and even more planning to obtain.
It can be done, but it must be done correctly, and that takes a good game plan, and some $$. :cheers: |
ski... check out the parts list my sig... i hope to have initial results in the next few weeks... it should get me where i want to be.
The guy I bought my 383, blower and full exhaust from spent originally almost 15 thousand on this combo. Sorry this combo isn't N/A.
[Modified by BAM92, 1:10 AM 10/10/2003] |
Re: 400rwhp on N/a spec ...? (BAM92)
Ok, lets get this going: Heads, you'll need heads. AFR 210's and a 396 stroker, as for cam the good'ol CC306 should do it. Of course the basic stuff should be there too, like long tubes, 58mm TB, good exahust, valve train (rr & chain) , p&p intake, injectors, etc, etc...
Rough estimate: Stroker ~$3000 Heads ~$3000 Cam ~$300 Headers ~$500 Exhaust ~$700 58mm TB ~$300 Valve train ~$500 Injectors ~$300 So right here are $8600 plus you have to count for all the other misc stuff like gaskets, tunning, new clutch to handle the power, and all that crap. In the end it will be $10000. Hope it gives you an idea of what to expect, although this combo will give you a lot more than 400rwhp n/a. :cheers: |
Re: 400rwhp on N/a spec ...? (Darkness)
Ok, lets get this going: Heads, you'll need heads. AFR 210's and a 396 stroker, as for cam the good'ol CC306 should do it. Of course the basic stuff should be there too, like long tubes, 58mm TB, good exahust, valve train (rr & chain) , p&p intake, injectors, etc, etc... Rough estimate: Stroker ~$3000 Heads ~$3000 Cam ~$300 Headers ~$500 Exhaust ~$700 58mm TB ~$300 Valve train ~$500 Injectors ~$300 So right here are $8600 plus you have to count for all the other misc stuff like gaskets, tunning, new clutch to handle the power, and all that crap. In the end it will be $10000. Hope it gives you an idea of what to expect, although this combo will give you a lot more than 400rwhp n/a. :cheers: Then u got 2 add the other $10,000 for the twin turbo setup :cool: :cool: |
[QUOTE]The guy I bought my 383, blower and full exhaust from spent originally almost 15 thousand on this combo. Sorry this combo isn't N/A.
QUOTE] Sounds about right. |
Re: 400rwhp on N/a spec ...? (Hammer)
Instead of going with a 383 stroker, why not just snag a 400sbc and punch it to 406. Wouldn't this be cheaper and make more power?
I picked up a 400sbc w/steel crank for $75 here locally. |
Then u got 2 add the other $10,000 for the twin turbo setup :cool: :cool: You won't be able to get both combinations to work with the same parts. To make the RWHP figure, you'll need to bump the compression ratio up. That makes it "nearly" impossible to do the turbo setup without new pistons, so then the entire rotating assembly will need to be re-balanced. If you PLAN on a turbo set-up, build the motor for a turbo from the start. You won't get the HP figures you want from the start, but you also won't need to completely tear the motor down. You'll only need to put a new cam in when the turbo system is installed. |
Re: 400rwhp on N/a spec ...? (Joe90)
Then u got 2 add the other $10,000 for the twin turbo setup :cool: :cool: ...and new pistons for the motor as well...aka total rebuild. You won't be able to get both combinations to work with the same parts. To make the RWHP figure, you'll need to bump the compression ratio up. That makes it "nearly" impossible to do the turbo setup without new pistons, so then the entire rotating assembly will need to be re-balanced. If you PLAN on a turbo set-up, build the motor for a turbo from the start. You won't get the HP figures you want from the start, but you also won't need to completely tear the motor down. You'll only need to put a new cam in when the turbo system is installed. |
why spend Big bucks...
ATI Procharger $4000 + installation = +400 RWHP ---and it's WAY easier than a turbo setup. |
Re: 400rwhp on N/a spec ...? (HC4-Vette)
I took a drive in a wrx sti (highly mod), and it turn me off sc and onto turbos so im going 2 make the 1st built and tune turbo australian vette
