E Brake removal
How do you get the 2 piece L shaped braket that attaches to the cable out from the brake shield? :confused:
Re: E Brake removal (jac1502)
I'm not sure if you can get them out from the outside or if you have to remove them from inside after removing the rotor (I would guess the latter though).
I can tell you that I could not get mine out either way because the two pieces were rusted together. I had to drill out the pin and then I removed it. |
Re: E Brake removal (jerryp58)
i have everything apart except the spindle. could you get the new piece in without removing the shield or spindle?
