Whats the best tranny fluid 700R4 To use?
Like the B&M, or what my trans was rebuilt 20k miles ago.
Am using an after market kooler, along with A Dearl Pan, 1 1/2 more quarts of fluid. Dearl Pan from Jegs. Please lwt me know. thank you tony :flag [Modified by oldace84, 4:55 PM 11/7/2003] |
Re: Whats the best tranny fluid 700R4 To use? (oldace84)
Well you can ,
A) stick with clean ATF recommended fluid, and change intervals or, B) get verybit of fluid you can outta it, and run stright B&M Trick Shift. I ran this stuff for 4 years in my 700r4 '83 Z28 450HP street daily, and it was a happy tranny!!! :D C) Listen to all these yuppies, and buy 10$ a qt synthetic,ultra slick, BS tranny fluid that offers little signifigance.... Thats my 2 cents , but i speak from experiance. |
Here I go again.......
Royal Purple :cheers: |
MOBIL 1 ATF :thumbs:
In the 4L60e, use fords Dectron V thing.
I know a GM test engineer personally, his job is to blow up transmissions for durrability tests. Fords fluid lasts the longest. Synthetic is a terrible choice for the 4l60E, it can actually decrease life. add a big cooler and call it good :thumb: |
Re: Whats the best tranny fluid 700R4 To use? (TreyZ28)
i run valvoline synethetic ATF in my 700R4. runs good and shifts hard! :)
red line.......
Re: Whats the best tranny fluid 700R4 To use? (smallblock)
:iagree:
Re: Whats the best tranny fluid 700R4 To use? (Corvette0096)
I swapped the stock fluid out at 24,000 mls. for Mobil 1 Synthetic ATF. It made the shifts a lot smoother than with the stock fluid.
After all what I read I would probably buy genuine GM ATF Dexron III ($2.60/qt. here at my dealer) and change it every 20,000 miles. |
Re: Whats the best tranny fluid 700R4 To use? (Mad-Mic)
any dextron III
the cheaper the better, this way you can change it more often I use valvoline but not the synthetic. rather than spending 2 or 3 times as much on synthetic, you are better off changing it 2 or 3 times more often. because no matter what brand it is, once it is burnt, its junk. |
