From dead with a code 33 to 55 degrees total timing in one day.
I decided to drive the vette to work today and just a few miles from home check engine light comes on and the car will idle but not accelerate. So I grab a piece of wire and pull code 33.
I called work and my friend looked up code 33, MAF sensor signal high. So we decided the thing to do is unplug the maf and let the ECM substitute values. Well, that didn't really work, still zero throttle response but I manage to drive the remaining 20 miles at 3100 RPM where it ran OK. We pulled the schematics, I find it very helpful to work in the bay right next to our Corvette specialist. He's on vacation but the books are just a few feet away. No power to MAF so my doomsday mind goes to burnoff module. No power to burnoff module which is powered through the 10AMP gauges fuse. Fuse was blown, this fuse does not actually power the gauges, my dash was always fine. With a handful of fuses we start connecting and disconnecting. Turns out that the overdrive relay was shorted, we noticed the light would come on for a second then the fuse would blow. Taking the burnoff module out of the loop reduced the draw enough to check other devices on the circuit. We disconnected the OD relay and all was good, except for that off idle flat spot.... We started throwing timing at it. And at 7:45 tonight there were four very experienced techs wondering how a small block could be taking 55* of total timing, not pinging, and now running like mad. It's like a whole new engine, throttle response is quick and amazing. I always knew there was power, but this is great. So sparked was the conversation about the 12* timing mark differences between some 400 blocks. You might remember that Jesse and cork built identical motors and ran within a 1/10 of a second with a 12* difference in timing. Even if that is the case, 43* is still alot of timing. I tried lugging the engine in 6th to force a ping and heard nothing. It's a little hard to swallow but if that's what it wants, that's what it wants. I definitely need to make sure my knock sensor is in good working order though. So, on the way home, as I passed by the place I was stuck in the morning I dropped into fourth at 70 and found myself celebrating at 118 shortly thereafter. Very shortly therafter. I think I'm glad I broke down this morning :confused: |
Re: From dead with a code 33 to 55 degrees total timing in one day. (Ski2Tee)
woha, thats amazing, atleast to me.
:eek: :crazy:
Re: From dead with a code 33 to 55 degrees total timing in one day. (vinnies87)
how do you know its 55 degrees timing :cheers:
The outer ring on your harmonic balancer may have slipped, giving you a false reading. You might want to check TDC on #1 cylinder with a tool(piston stop or such) and see if it is correct.My $.02.
:chevy |
Is Your Vette -85?
Re: From dead with a code 33 to 55 degrees total timing in one day. (Curveit)
The outer ring on your harmonic balancer may have slipped, giving you a false reading. You might want to check TDC on #1 cylinder with a tool(piston stop or such) and see if it is correct.My $.02. :chevy |
Re: From dead with a code 33 to 55 degrees total timing in one day. (CORKVETTE1)
As read with a MAC tools timing light, against an ATI 360 degree marked damper. I'm curious why you ask...
edit:Just read the above posts, I don't know that this damper could seperate like that. What you guys speak of did happen on my old motor with the stock balancer. Took me some to figure out why my readings were out in left field. Talked to another tech at wotk today, in his experience (20yrs with chevy) he had two similar hot rod motors, one that took 58 degrees and one that took 45. "Turn'em till they ping then take out 4 degrees" These were either oval or dirt track motors he and a friend used to run, 434's I believe. [Modified by Ski2Tee, 7:44 PM 12/12/2003] |
the only way to check total timing on that would be on a wheel dyno so you can load the car and then check the timing other wize you are not checking right total timing right :cheers:
I guess the question is then, what am I seeing when the throttle is cracked and how will it differ from on the dyno? Would it generally show more or less?
you are looking at no load there are about 24 different tables the computer go through from no load to full load so a static timing test like you did tells you nothing :cheers:
you are looking at no load there are about 24 different tables the computer go through from no load to full load so a static timing test like you did tells you nothing :cheers: |
these cars arent like a carbed car to tune if it was only that easy :cheers:
Thank you!! I now understand better what goes into tuning these things.
Funny how you can spend years diagnosing driveability concerns on various engine control systems and not ever have to be concerned with such details necessary for maximizing output. |
BUT IT IS FUN OR WE WOULDNT BE DOING IT :cheers:
