which exhaust crossover pipe should I go with ?
going to install a GHL exhaust system in my 2000 c5 coupe automatic. which crossover pipe should i use? or does it really matter. should i go with the magnaflow x-pipe or the corsa? i want to keep the o2 sensors.
Re: which exhaust crossover pipe should I go with ? (birch64)
I have a Corsa X-Pipe and like it fine. I still have the O2 sensors and have no issues! :seeya
I found a local muffler shop that was also a magnaflow dealer and had them weld in an x-pipe before I installed my GHL's. It cost me about $150.00 compared to buying the bolt in style for about $275.00 and doing it myself. :seeya
I just had the GHL Magnum Plus installed with the Magnaflow X-Pipe. The Magnaflow fit and worked perfectly. I purchased mine from Shawn at TheLAPD.com.
Have GHL bullets, with magna flow x pipe. Had LAPD install, sounds GREAT! :cheers: :lurk: :thumbs:
Re: which exhaust crossover pipe should I go with ? (MACSZ06)
mike if you get rid of your stock exhaust let me know. Im looking for a 2000 exhaust as i gave mine away and am looking to do some back to back testing of my dynomaxx headers and stockers.
Dave |
Re: which exhaust crossover pipe should I go with ? (TT_Vert)
Use the X pipe that comes with LT headers.....I know you want them... :yesnod:
:cheers: |
Re: which exhaust crossover pipe should I go with ? (99SilverC5Coupe)
Before I got my headers, I had the Magnaflow x pipe and the GHL Magnums - PERFECT fit and great sound
