bleeding power steering..
how do i bleed this thing? I think I'm gunna tackle it tomorrow after I finish the heater core.. I cant take manual steering anymore.
i know i know, I'm a whimp |
Hook everything together and fill it up with PS fluid. Start the car and turn the steeringwheel end to end. Check fluidlevel,fill it up and repeat..
It is better to try and get most of the air out of the system before starting your engine. This will prevent the pump from whipping the fluid into a froth with the air that is still in the system if you start the engine without getting most of it out.
With both front wheels off the ground, fill the pump reservoir to the HOT mark on the stick. Lit is sit a couple minutes. Now rotate the steering wheel lock to lock about a dozen times. Refill the reservoir to the COLD mark on the stick. Repeat the lock to lock turns another dozen times. Refill again if necessary. Let the car down and start the engine. Make another couple of lock to lock turns (do not hold at full lock more than a few seconds.) Recheck the fluid level and refill to the COLD mark if necessary. Go for a short drive. Recheck the level one more time. You are done! BTW, I always recommend that you fill the system with genuine GM power steering fluid. This fluid is available at any GM dealer. It is the only fluid that is specifically formulated for use with the Saginaw pump. Jim |
I have always had good luck doing it like Jim has said. I usually let mine set overnight with the wheels off the ground. The next morning give it a few lock to lock turns and if the level remains acceptable you know you are ok.
sounds harder then I thought it would be, okay, I'll jack up the front tonite and do it tomorrow (its supposed to be cooler tomorrow)
