axle seal leak, this makes no sense , but,
It was leaking and I cleaned it up with Brakekleen and it stopped. :yesnod:
It's been about a week without a drop or a drip that I can see :D Maybe it swelled the rubber. :skep: Gonna see how long this lasts. :chill: |
Maybe there was just a bit too much fluid and it was coming out the vent??
nope, right side was leaking and I could see the trail coming from the seal. :confused:
mine showed no signs of leaking for about 1500 miles after cleaning with water.---- its back--- mine appears to leak from the axle seal. I plan on changing it this fall, thanks to all the info i learned on this forum--- thanks patches, dope, c5tech,mike mercury---and many others
still no leak :thumbs:
still wondering if the brakekleen caused the seal to swell :confused: . |
How much play do you have on the left axle where it goes into the diff?
I think my carrier bearing is going. I have a bit of play on that axle and the seal is toast. |
gee , I didn't even check :banghead:
LH seal cover and seal replacement
Mine leaked 3 times.
This time, dealer will replace lh cover AND seal. Glad to see they are trying new cover.....I think it could be a machining issue. |
