Any Track Results With AFR Heads!!
So far we have seen impressive numbers on the dyno. But has anyone got 1/4 mile results to share with us.
i have asked question several times and got a couple replies ... with the AFRs commonly getting over 400rwtq i am expecting decent numbers...but to date mid-high 11s
Originally Posted by Face
Dyno queens. :leaving:
:willy: :lurk: :D
:cheers: :lurk:
:lurk: Does make ya wonder why we see all the big dyno numbers and no ETs..
HMMMMMMMMM!! :steering: |
and have him post exact #'s . Last time I was out at the track I believe the car was around 12.00/12.01. This was at LACR at elevation (uncorrected time). MPH I cant remember. Was beating on my c4. This car absolutely RIPS at all RPM's! Sounds very stealthy, too I might add. Oh yeah c5 vette, around high 480's at rear wheels. Beleive it. I'll contact him sometime this weekend. Ron |
12 flat is pretty sad, for 480 at the wheels.
I hope to have an answer for you in a week. :cheers:
You guys crack me up....
What exactly is a "Dyno Queen"...?
If you put 10 cars on the same dyno on the same day (to eliminate AS MANY variables as possible) and hypothetically they all weighed exactly the same and had the same driver, rear gears, transmission, and just about every other VARIABLE you could think of was kept the same....the car that made the most power on the chassis dyno would get you down the track quicker with a higher terminal speed...END OF STORY. A chassis dyno means the engine is "accelerating" a drum (or drums) of a certain fixed weight and it takes "X" amount of time to do so. An engine/driveline combo that can accelerate this drum the fastest (and show the highest recorded power) will also be able to accelerate the car the fastest as well.....Your tires don't know whether they are accelerating a rolling drum or your favorite ride down a stretch of highway. Track results, much like dynos, have way too many variables to be used for any type of evaluations unless all the different variables are accounted for....DA, or Density Altitude being the largest concern. Track prep would be next on the list. Bring the cars in question to the same track on the same day and now you have something to compare if you wanna know who's Johnson is a little bigger....you get my point. And the fact of the matter is the more powerful car might not turn out to be the winner if the driver of that car was inexperienced and didn't know how to drive it to it's full potential. Come down to Bakersfield on Dec. 4th and put down your $100 for the private track rental that day (look for more info in the "Pacific" part of the "events" section)....I'll be there as well as quite a few other AFR heads/cam cars and we will see how the chips fall....I especially invite all of the folks that claim AFR cars are "Dyno Queens" so you can prove to me once and for all how your lower chassis dyno #'s provide much quicker and faster quarter mile times. And lets factor "race weight" into the equation as well....Another "novel" concept. Bring it on....See you in Bakersfield on the 4th. Tony M. |
Come down to Bakersfield on Dec. 4th and put down your $100 for the private track rental that day (look for more info in the "Pacific" part of the "events" section)....I'll be there as well as quite a few other AFR heads/cam cars and we will see how the chips fall....I especially invite all of the folks that claim AFR cars are "Dyno Queens" so you can prove to me once and for all how your lower chassis dyno #'s provide much quicker and faster quarter mile times. And lets factor "race weight" into the equation as well....Another "novel" concept. |
If you put 10 cars on the same dyno on the same day (to eliminate AS MANY variables as possible) and hypothetically they all weighed exactly the same and had the same driver, rear gears, transmission, and just about every other VARIABLE you could think of was kept the same....the car that made the most power on the chassis dyno would get you down the track quicker with a higher terminal speed...END OF STORY. A chassis dyno means the engine is "accelerating" a drum (or drums) of a certain fixed weight and it takes "X" amount of time to do so. An engine/driveline combo that can accelerate this drum the fastest (and show the highest recorded power) will also be able to accelerate the car the fastest as well.....Your tires don't know whether they are accelerating a rolling drum or your favorite ride down a stretch of highway. Track results, much like dynos, have way too many variables to be used for any type of evaluations unless all the different variables are accounted for....DA, or Density Altitude being the largest concern. Track prep would be next on the list. Bring the cars in question to the same track on the same day and now you have something to compare if you wanna know who's Johnson is a little bigger....you get my point. And the fact of the matter is the more powerful car might not turn out to be the winner if the driver of that car was inexperienced and didn't know how to drive it to it's full potential. Come down to Bakersfield on Dec. 4th and put down your $100 for the private track rental that day (look for more info in the "Pacific" part of the "events" section)....I'll be there as well as quite a few other AFR heads/cam cars and we will see how the chips fall....I especially invite all of the folks that claim AFR cars are "Dyno Queens" so you can prove to me once and for all how your lower chassis dyno #'s provide much quicker and faster quarter mile times. And lets factor "race weight" into the equation as well....Another "novel" concept. Bring it on....See you in Bakersfield on the 4th. Tony M. Hurry up with those 225's. I have a 238/244 on a 115 I want to drop in with the 225's on a stock 348 to break the 500 rwhp mark. I have NO problem being a dyno queen! How far out are we still? Keep up the excellent R&D. :yesnod: :cheers: |
my track times are in the sig :ack: but i never been to the track, so dont give me no sh$t. i blew my rear on the 3rd pass. so i only got 2 runs in. thats my first run ever in the sig. the second run i didnt go the full quarter mile :crazy:
Originally Posted by Geneus
Ouch...2 runs and the rear gave way? :eek: Pray for me, brother. I hope I don't end up that way next week. :( What did you launch at? What tires were you on? Based on your first two runs, I'm guessing street tires, since at your power levels with slicks or DR's you would have easily been in the low to mid 12's, even not being that experienced. To break the rear on street tires (if in fact that was what you were on), something had to have been seriously wrong before you even raced. :yesnod:
