Was curious.....do you have to open the computer case.....mine computer has a sticker on it with a repair number and barcode but no 4 letter code.....
thanks for the help |
It's on the silver sticker that covers the erase window on the EPROM in the MEMCAL. Pull the small cover off the ECM and you should be able to see it.
[This message has been edited by Aaron's 87 (edited 07-20-2001).] |
Jeff,
You have a 1990 automatic with 3.07 rear. The sticker on your chip will say ANHT with some numbers. There are a few nuts to remove that hold the ECM over your battery area. Once those are removed, you can lift the ECM up and on the bottom is a small cover that comes off to reveal the Memcal with the chip in it. |
thanks for all the help by the way Craig....appreciate it a lot...
Can't wait to test out the new chip...I just want this thing to run nice and cold this summer for my trip to Maine... Hopefully...the chip & 160 thermo will do the trick.... http://www.corvetteforum.cc/ubb/biggrin.gif Jeff |
Originally Posted by XtremeVette:
[B thanks for all the help by the way Craig....appreciate it a lot...
Can't wait to test out the new chip...I just want this thing to run nice and cold this summer for my trip to Maine... Hopefully...the chip & 160 thermo will do the trick.... [img]http]//www.corvetteforum.cc/ubb/biggrin.gif[/img] Jeff [/B][/color] |
Yeah, what they said
