Anybody know where I can find the horn relay??
Thanks for the help. Lou |
Pirate Lou,
The horn relay is located in the relay module under the right side of the I/P. You will have to remove the lower trim panel.Pass side. It is located with a few others in a covered module. After you remove the cover the horn relay shud be on the left, looking towards the front of the I/P. |
Lou,
Thanks for your help. |
PirateLou,
I gave you a 'bum scoop'. The relay will be on the right looking forward. Sori about that! |
