Trying to judge some times
Tires/gears/engine Let's hear your best times |
Goodyear GSC's, 3.54 gear, stock 94 LT1
Best 60' w/ stock 2.59 gear=2.037 Best 60' w/ 3.54 gear=2.051 |
Tires/gears/engine
Let's hear your best times Best 60fot 1,64 BFG Drag Radial 275x50x15 3,73 355 see a video http://racing.mine.nu/videos/tulling...0tomas%20k.asf |
Goodyear Ultra plus-auto,3.31-1.89
Michelin Pilot--1.93
BFG-Drag radial-1.91 3.45 gears stock LT1,6 speed |
1.56 60' (1/4 mile was 11.02 @ 128 mph) on 315/35/17 drag radials 20 psi.
Lingenfelter 383 with nitrous (only after hitting 2nd gear on that run), 700R4 trans, Vigilante 3500 converter (stalls to about 2600 r.p.m.), 3.33 gears....... recently put in 3.73 gears, ALL poly suspension bushings, completely rebuilt suspension, Koni shocks, and MT ET Streets 26 X 10.5 X 15 tires....looking for 1.4's 60 ft. time and 10.5's 1/4 mile with a little more N20. |
These are pretty crappy so let me put it in perspective. 100% humidity, 80+ degrees.
2.03 on BFG Drag radials 3.45's possible slipping clutch |
Gsc Runflats/ 2.125/ Stock LT1
1.9891 in sig with a stock motor, conveter, and rear.
New 60 is 1.78 with 2800 vig, 3.73 and stock motor. Gota love those drivetrain mods http://www.corvetteforum.cc/ubb/biggrin.gif http://www.corvetteforum.cc/ubb/biggrin.gif!! |
Stock 700R/4 and 2.59 gears, on GY Eagles: 60'=1.98sec
1.62
et streets 2800 protorque 345 gears |
Stock L98
2.59 gear Automatic Worn out GSC's 2.015 60' |
1.997 255/50-16 Gatorbacks 2.73:1 14.1 ET
1.887 255/50-16 BFGoodrich Comp T/A 3.07:1 13.7 ET 1.907 315/35-17 Dunlop SP8000 3.07:1 13.6 ET I ran better a better 60' on the BFG but my car just hooked that run, I think my 2nd best 60' was 1.94-5 on those tires. I have also run a 1.91, 1.92, & 1.97 with the 315's the only time I took them to the track. |
1.758 60'
3.42 Gear, MT ET streets, 700R4 2600 stall converter, 383, Super Ram SSM lift bars BW |
1.552 60 ft
383 SR motor 3.45 gears 3000 rpm Vigalante converter good luck Beach Bum |
Miniram'd L98/Nitto Drag Radials (32psi)/ 3.45 Gear/ ZF6
best 60'= 1.99 Rest of mods on website link in Sig. |
1.86 3.45 6 sp. mt etstreets.
See whats going on here ? Manual guys are up to .2 slower. |
85 Corvete
Completely stock 90K-miled engine/700R4 Worn-out Defender HRX 255/50 16's 2.73 gears 14.00@101mph 2.01 60' (No stalling it up, just WOT from idle) .570 light [This message has been edited by TIMSPEED (edited 07-25-2001).] |
