Battery removal question
I am storing the vette as usual,( :( ) this year however I am removing the battery (don't want to take any chances) and it will be hooked up to the trickler. I heard something about needing a code for the radio when the battery is reconnected?? Anyone heard this? I bought my vette used and I don't know how to locate the radio security code..call dealer with Vin#????
2nd- one of my key remotes has a dead battery and the other is probably going to die soon...do I have to do a key relearn? or is that only if the PCM/BCM is disconnected?? Thanks Frank I should add I have an 01 |
Thanks Frank |
you actually set the THEFTLOCK radio code yourself... with the key turned off, does a little red light flash on the face of the radio? If not, the THEFTLOCK feature was never activated and you are good to go:thumbs:
if you have your manual...look up Theft deterrent radio if a code was set... try this :thumbs: https://www.corvetteforum.com/techti...=164&TopicID=1 |
okay.. I am bored at work :crazy:
http://img.photobucket.com/albums/v145/darwal8817/1.jpg http://img.photobucket.com/albums/v145/darwal8817/2.jpg http://img.photobucket.com/albums/v145/darwal8817/3.jpg save you from having to go to the manual :thumbs: |
Thanks guys! :cheers: :cheers:
can anyone confirm if I have to do the long version or key relearn when i disconnect the battery? The reason I am asking is that although I will disconnect the battery..I do plan on turning the engine over once or twice during the winter on a nice day..I don't want to let the engine sit from Nov-March without turnover. |
ttt
EDIT: oops.. I just realized that you were asking about the key fob again :o you werent asking about the radio :D
Brain thanks a lot for the info and for posting the owners manual too :cheers:
we'll see if anyone chimes in on my key-relearn question. My best friend is a good mechanic so i am sure he willl help out...but if I have to do a long key learn process everytime I reconnect the battery , then I have got to figure something else out. thanks again |
If you don't have the radio code, there was a post yesterday that dealt with how to unlock the radio once power is disconnected. Check it out. Otherwise, a dealer can unlock it for you, of course at a charge.
If you change the battery in the fob, it must be relearned to the car. Owners manual tells you how to do it I believe. |
Instructions for what to do after fob battery replacement are also inside the fob, on the cover.
don't take the battery out of the car just get yourself a battery tender plus, plug it in hook the cables up and forget it. :thumbs:
