its a shunk....
well...ive done all the u-joints and wheel bearing on my 85....front and rear recently ive been getting a SHUNK when i put it into reverse.... I almost sounds like a cue ball hitting the 8 ball....not a clunk but a shunk http://www.corvetteforum.cc/ubb/smile.gif Could i have no fluid in the differential...ive notices some leaking, but it looks like its comming from the blow hole..the sound seems to be comming from the rear end..but im having a hard time finding exactly where the sound is because it only happens (usually) with the first gear move of the day...and when i go home from work... thats is the only time it does it...i put it in drive...no shunk...can put it back into reverse...no shunk......any help is greatly appreciated.. |
My guess would be that is coming from the transmission. You should have a good trans shop check it out and see if you should live with it or fix it.
ttt
